Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 27-02-2003, 20:12
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 287 Hurricane Floyd
Unread 27-02-2003, 20:15
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
uummmmm, WOW. That is a truly amazing robot. Nice job.
3 things, what powers the swivel wheels in the back, as far as lowering them or raising them to adjust the tilt of the stacker mechanism.
2nd, what raises the stabalization arms that hold the boxes in the stack when your lift is tilted as it is in the picture
3rd, do you hve a way of righting your robot, it seems that it's design could make it easy to fall/ tip over
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 27-02-2003, 21:50
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Can you guys steal opponent stacks?
I like your method for "protecting" a stack. I also like the way you guys made your drive suit your design.
Nice Robot...
Unread 28-02-2003, 09:52
whizbang whizbang is offline
#0287 (Hurricane Floyd)
whizbang is an unknown quantity at this point
287 Hurricane Floyd
The tilt mechanism is controlled by the window lift motor and a chain drive. It is not a top heavy as it might look, the center of gravity is low. Yes, we can steal stacks and drive them to the other side.
Unread 28-02-2003, 10:49
Jestin McCarthy Jestin McCarthy is offline
AKA: JT Money
#0131 (C.H.A.O.S.)
Jestin McCarthy has a little shameless behaviour in the past
Send a message via AIM to Jestin McCarthy
Re: 287 Hurricane Floyd
Nice robot guys! Ill be looking foward to seeing you at the manchester regional. Hopefully ill have two of your former leaders with me. They both happen to attend MIT:-) anyways good luck and ill be watching for you guys to climb up the standings.
Pit Crew member "you break em we fix em"
http://chaos131.tripod.com/index.html
Unread 28-02-2003, 11:05
287 Hurricane Floyd
I hope you can bring those two up. We miss them very much, they did so much for the team and the school.
Mr. Ryon
Team 287 advisor
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
