Thread Tools |
Rating:
Display Modes |
Re: pic: Bit Buckets 2015 Offseason Drivetrain
We built it today!
A photo, as promised: ![]() Anyone want some small wood disks? ![]() We've been generally satisfied with our results. The chassis is lightweight and extremely strong and stiff; it survived being jumped on, dropped and pounded with no damage. In total, it took about 4 hours of laser time. Hopefully, we'll get it running over the next couple of weeks, as we replace a few parts on which we made mistakes and receive the stuff we ordered from Vex. However, I'll wait a little on releasing the CAD; we caught a few bugs I'd still like to fix. Edit: It's also very inexpensive to produce; each chassis takes about $30 of wood and $10 of hardware, not including powertrain components, compared to $189 for an AM14U frame or other COTS or custom options. Last edited by z_beeblebrox : 07-12-2014 at 22:07. |
What is the cutting area of the laser cutter?
If you do something similar in the future, cut the following letters into each disk:
T, U, I, and T. Add your team number, and use as giveaways. When you finally get "a round TUIT"... ![]() *ducks* |
Another meeting tomorrow, another iteration ready to fab:
![]() This version includes a significant redesign of the gearbox and its mount, allowing for a stiffer gearbox and more sensible encoder placement. New t-slot design should better retain nuts. The battery mount was enlarged and holes for a velcro strap were added. Small improvements to clearances, press fits and lightening holes were made throughout the model. This will be the last iteration of the drivetrain before build season. We received our Vex Pro and FIRST Choice orders, so will be assembling the full powertrain and wiring all the electronics on this version. Here's all of the wooden parts, laid out for the laser: ![]() |
We tested our last-week's robot base to destruction with a car.
http://youtu.be/kjUfTZ4KFO0 The next couple of drive-overs resulted in a flat tire on the Volvo. This week's robot is closer to working with real wheels and motors and electronics! |
#7
That was what I predicted, watching the video. Poor little car.
#8
We worked more on assembly and wiring today. Photos soon to come.
We do have two exciting documents to share: the CAD model and our engineering journal. The CAD model posted contains a few bugs that we fixed with a drill and jigsaw, but is still a basically functional drivetrain: https://grabcad.com/library/bit-buck...n-drivetrain-1 The engineering journal is a description of our process and decisions in building this project. It is not an exhaustive document, nor is it a particularly polished one, but it will contain helpful ideas for designing things with plywood: https://docs.google.com/document/d/1...it?usp=sharing Have fun and feel free to ask any questions. Last edited by z_beeblebrox : 18-12-2014 at 00:23. |
#10
Some pictures:
http://www.chiefdelphi.com/media/photos/41024? http://www.chiefdelphi.com/media/photos/41023? http://www.chiefdelphi.com/media/photos/41022? http://www.chiefdelphi.com/media/photos/41021? http://www.chiefdelphi.com/media/photos/41020? http://www.chiefdelphi.com/media/photos/41019? http://www.chiefdelphi.com/media/photos/41018? |
#11
Pretty!
I hope you have a chance to bash this bot up in some open field defense. I'd really like to see how the plywood base holds up compared to, say, and AM14U, given that yours has much more cross-bracing. If it works OK it could be a really cheap way to design custom chassis (cheaper than laser cutting and bending aluminum anyway) |
#12
Latest iteration looks great! Get some bumpers and weight and drive it like you stole it.
I got to see the previous one (in the car crushing video) in person. It's an extremely clever design that somehow ranks high in all of the desirable categories; extremely stiff, relatively lightweight, and can literally be cut out and assembled in an afternoon out of $50 worth of material. The drop-out wheel modules are pretty neat too, I don't think I've seen something done quite like that before. Great prototype, I can't wait to see you apply these design concepts to the rest of your robot this season. Might be my new favorite build material. |
#13
It appears that some parts were not saved in the same place as the rest of the project and were left behind when put on grabcad. Most of these parts are spacers and things that are not important
#14
I just looked over the GrabCAD model and it looks like everything is there. I used SolidWorks Pack and Go, so it should have captured all of the parts regardless of location. |
#15
The Trotec Speedy 300 at our build space, Xerocraft Hackerspace, has a 29" x 17" bed. We made the top and bottom in 3 pieces to let us make a 28" square robot.
