Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 08-12-2014, 17:09
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Team Xbot 488 Beta Presentation (Redmond, WA)
Originally Posted by jojoguy10 View Post
Yes, definitely a great learning experience!
If Larry is here and reading this, do you think you can post a link to your PowerPoint? That would be awesome!
I will think of some questions to ask soon.
-Joe
Update:
Here is a link to Larry's PowerPoint after he emailed it to me:
https://drive.google.com/file/d/0B1z...ew?usp=sharing
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 03-01-2015, 19:30
pensono pensono is offline
FRC #5495
pensono is an unknown quantity at this point
Neat presentation, it outlines what's new and different really well. I didn't realize the roboRIO supports Java 8 now, which is awesome because Java 8 is awesome. Does the roboRIO read java bytecode? if so, we could be seeing some bots programmed in jvm languages like Scala and Clojure, which would be really cool.
Could you post the code you used for the perf testing? I'm curious how you tested it.
Unread 03-01-2015, 19:34
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I think it would be fairly easy to run other JVM languages because the roboRIO uses the standard Oracle Java SE Embedded (you actually have to go to the Oracle site to download it).
Unread 03-01-2015, 19:45
FRC #5495
Oh cool. Depending on weather the build tools are modifiable or not, this could be fairly easy. If they're using something like Gradle, then adding in another language to your project will be trivial. If they aren't using something like gradle, we'll just have to hope they've opensourced it. GitHub's a sponsor, maybe they'll post it there?
And if it's java, we can get minecraft to run on it. Anybody want to write some OpenGL drivers?
Unread 03-01-2015, 20:42
Dartmouth 2020
AKA: lopsided98
The source for WPILib is available, but you have to have an account on the FRC TeamForge to access it. They might allow anonymous access soon. I believe the build scripts still use Ant, so you might be able to make it work.
I'm thinking about trying to write autonomous scripts in Javascript with Nashorn, but it might not be worth it because we don't have to reboot to upload code anymore.
