Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
Unread 09-12-2014, 03:55
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Re: pic: 3 CIM WCD Ball Shifter Dead Axle
Originally Posted by Joey Milia View Post
The PEM inserts are pressed into the opposite side of the plate from the bolt, they have a flange but the flush ones are pressed into the material flush which cold forms the material into groves in the nut. They can be sourced from mcmaster here http://www.mcmaster.com/#captive-nuts/=uy130o
GRT has used the standard ones in our GB for the past three years and the flush ones in the 2014 GB. You'll need a hydraulic press if the plates are anodized but if it's just raw aluminum an arbor press should do fine I think.
More info on flush ones here http://www.pemnet.com/fastening_products/pdf/fdata.pdf
and a lot more info on their website http://www.pemnet.com
Great. Thanks for the info. I'll be sure to look into it.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
