Go to Post I have a feeling that we're about to deprive the world of Poof balls for a while. - DCA Fan [more]
Unread 09-12-2014, 09:29
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: 3 CIM WCD Crazy Geabox
Unread 09-12-2014, 09:35
Knufire Knufire is offline
Re: pic: 3 CIM WCD Crazy Geabox
I would be wary of double loading the CIM pinion like that.
Originally Posted by magnets View Post
I can't see exactly what you're doing with your pinions, but 254's been running double loaded pinions in all their 3 CIM gearboxes.
Originally Posted by AustinSchuh View Post
This is even more reason not to do it. 254 bends CIM shafts every now and then in the drivetrain. I didn't believe it was possible until I saw it myself.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 09-12-2014, 10:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That's not a cim shaft, that's a regular 3/8" hex shaft.
You're really starting to push the envelope for these sorts of gearboxes, but there is a limit and you've reached it. Now the weight of your box is becoming almost solely dependent on how well you lighten the plates and gears; each new design has to have a certain minimum of gears in it to work.
Have you tried a different design like with belts?
Unread 09-12-2014, 12:07
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Team 254 uses dog shifting in their gearboxes. Which means that beyond just double loading the pinions, they are cantilevered at the end of the CIM shaft. In this design, and the others that I have posted recently, the pinions are very close to the base of the shaft. This means that the CIM shafts will take a fraction of the torque seen in 254's gearboxes.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 09-12-2014, 13:36
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Specs:
Weight 11.2 lbs including everything shown.
Height 3.3 inches tall. Top of the gearbox is 3.75 inches of the ground if running a 4 in wheel.
Gear ratios are 4.57 to 1 in high and 9.52 to 1 in low. (not really ideal)
Unread 09-12-2014, 13:41
Andrew Lawrence
Posts: n/a
Ahem.
Unread 09-12-2014, 13:50
Chris is me's Avatar
AKA: Pinecone
What does dog shifting have to do with pinion loading at all? Almost all gearboxes have cantilevered motor pinions, including this one. The only time I've seen a fully supported first stage pinion is when a team pressed 3/8 hex sleeves onto their CIMs.
While the distance from the motor and thus bushings matters, it's still going to be a concern here. It might work, but be careful.
I do like the low profile design a lot, but cleanly integrating three motors into a gearbox without excessive extra weight is indeed quite the packaging challenge - you'll always compromise *something* in the design. So you'll probably always get some nitpick on CD
Unread 09-12-2014, 16:02
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
I think he was saying that the bending moment induced by the torsion on the pinion gear is less when the gear is closer to the mounting plate. This would decrease the bending moment and the likelihood of bending the CIM shaft. I recall seeing one bent shaft on our 2013 robot (caused by some significant shock loads in the PTO/hanging mechanism). We used the same mounting scheme in 2014 and saw no bent shafts.
The dog shifter design usually spaces out the pinion by one gears face width. The design he has shown can place the pinion almost directly against the mounting plate.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 09-12-2014, 16:29
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I couldn't have said it better myself!
(Obviously, sense I tried and failed lol)
Unread 09-12-2014, 18:30
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
How much ground clearance do you have? Assuming a 4in wheel
(2015-?): 973
(2012-2015): 955
Unread 09-12-2014, 23:27
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
IIRC, (I'm not at my computer) it's got half an inch on a four inch wheel.
Unread 10-12-2014, 15:06
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Why don't you like it exactily? I think a flat configuration like this at least from a total robot packing components standpoint is ideal, I wish there was a COTS option with a configuration similar to this.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 10-12-2014, 17:11
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I am in love with the packaging as well, but there are too many compromises necessary to make it fit like this.
-The gear ratios are close together, and they're not really adjustable.
-You would have to take a standard 64t gear and cut a ball shifter bore in it.
-It requires two expensive bearings that are 0.75" id 1" od.
-two of the motors go through 1 or 3 stages of gearing, and the other goes through 3 or 5 stages of gearing.
-It's heavier than my other gearboxes.
It would definitely be cool to build one, and you wouldn't find a gearbox with a lower COG, but I think my other designs are a lot closer to ideal for my team.
Unread 10-12-2014, 20:22
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
As a side note, those bearings only cost a little bit on Boca Bearings, and you could use a bushing if you wanted to.
However, I see why you don't like this. Custom gears are tricky to machine without a softjaw or machinable collet IME.
Unread 11-12-2014, 00:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The cheapest I found them for was $25. Not super expensive, but that's $100 dollars per robot that could be avoided. We also don't have any experience ordering from Boca. Which is also not a deal-breaker, but it adds to the list of difficulties.
