Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Unread 09-12-2014, 22:36
Kabir Manghnani's Avatar
Kabir Manghnani Kabir Manghnani is offline
FRC #0649 (MSET Fish)
Kabir Manghnani is an unknown quantity at this point
Hovering FRC Robots
I'm sure you guys have all seen the Hendo Hoverboard in the NY Times recently. Its a fantastic piece of technology and FRC Team 649 got a chance to get up close and personal with it and hover the very first FRC Robot!
Hoverboard robots will never fly with the GDC, but in the mean time our 2013 robot Tobiko (Flying Fish in Japanese) has finally decided to live up to her name, hovering like the discs she shoots!
Special thanks to our friends at Arx Pax and Hendo Hoverboard for making this a reality.
Teaser: Team 649xHendo: http://youtu.be/I9O4O6JDQig
FRC Team 649
Vice- President
Programmer
Chairman's Lead
Scouting
The voices in my head may not be real, but they have some good ideas!
Unread 09-12-2014, 22:49
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
Re: Hovering FRC Robots
That really cool, I'm interested to see how they'd drive with defenders on them, I'm guessing they could maneuver similar to a mecanum drive
Alumni from 75 and 1885
Unread 09-12-2014, 23:00
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
The problem with hendo in this use, other than the copper floor requirement, is that AFAIK it can only be used to make things hover, it can't really be used for propulsion. It works by creating a magnetic field with the copper, and as the copper is flat, the field is only going to push up, normal to the surface of the copper.
Unread 09-12-2014, 23:05
Nope! I had a chance to see propulsion using the Arx Pax MFA (Magnetic Field Architecture) at their lab Its just a matter of how you shape the field, think of it this was, if the field is stronger on one end it can control propulsion by tilting and then driving the object (robot) forward.
FRC Team 649
Vice- President
Programmer
Chairman's Lead
Scouting
Unread 09-12-2014, 23:11
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Time for pit lanes and standard pit carts at CMP
Unread 10-12-2014, 01:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Sweet. What's the efficiency for moving a distance versus just wheeling?
Unread 10-12-2014, 01:27
Read Andy Grady's piece on the Placebo. Pay special attention to the 1996 version...
...then tell me that hoverbots will never fly with the GDC.
Unread 10-12-2014, 01:42
Naveed Riaziat's Avatar
Naveed Riaziat Naveed Riaziat is offline
FRC #0649
Naveed Riaziat is an unknown quantity at this point
Currently the system runs about 40kwatts/kg just for floating. Movement will come through shifting you center of mass to tilt the board, so, if I understand correctly, no extra energy in terms of the hover engine itself (you will of course have to find a way to move your COM). Basically, in terms of speed, availability, and efficiency, wheels still have the upper hand. Itll be a while before hover engines will be reasonable for long time periods.
But it floats so all these criteria are thrown out the window and hoverboard wins again.
EDIT: Apparently you can also change the strength of either engine to move too
