Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 10-12-2014, 08:16
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Using USB Sensors?
Originally Posted by 3175student17 View Post
Does anyone know how hard connecting an arduino with the native usb connector and communicating using serial 9600 would be in order to replace using an ethernet shield, or would it be easier to simply use the shield?
Beta testing team here. The RoboRIO has *some* support for USB<->Serial devices, like the Arduino and other FTDI devices. You should not need an ethernet shield to do this. Be careful about powering the Arduino over the USB on the RoboRIO though. I don't think it will let you pull more than 500mA (USB Spec) so no massively long blinky LED chains.
Unread 10-12-2014, 15:01
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
You can install additional drivers on the RoboRIO (provided it supports Linux) so software is generally not an issue. For USB, National Instruments does have a "durable" USB cable they were showing at St. Louis this year.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210962
Additionally, you could try using direct RS-232 or I2C with the arduino.
Unread 10-12-2014, 15:28
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
You could always attempt something similar using a camera pointed at the floor. NI provides some pretty easy to use optical flow VIs.
Unread 10-12-2014, 17:42
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Alas a standard webcam won't have nearly the frame rate necessary to keep up with a robot moving at 15ft/s. That's why mice have always been interesting since the new gaming mice have some pretty significant specialized processing power on-board. It is the case that some optics magic will need to take place in order to not have the mouse dragging on the carpet.
Unread 11-12-2014, 04:00
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
500 mA is the USB 2.0 spec'd max current for Vbus. You should not generally expect more than that from that standard.
That said, the roboRIO is designed to be able to operate with USB 3.0 cameras (at USB 2.0 data rates), but that means roboRIO can source 900 mA per host port so that those cameras function reliably.
