Go to Post It is impossible to be grumpy about anything when eating biscotti made by one's beautiful wife, drinking tea sweetened by one's own honey, warmed by a wood stove, and with a dog asleep on one's foot. Simply impossible. - pfreivald [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-12-2014, 15:53
Zentx's Avatar
Zentx Zentx is offline
AKA: Robert
FRC #3949
Team Role: Electrical
Zentx is an unknown quantity at this point
CAN connection on roboRio.
This is my first year on the Robotics team. I have familiarized myself with the RJ12-Serial connection for the CAN BUS on the cRio.
I was wondering how CAN will work on the new roboRio with Jaguars, since there is no serial port.
Do I only use the CAN - H and CAN - L wires of the RJ12 cable and connect it to the RoboRio?
Should I use a a different gauge wire to connect the wires to the roboRio? If so, would it cause bottle-necking?
Would I need a terminating resistor on the roboRio, or does it act like one itself?
Thanks.
Unread 10-12-2014, 15:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: CAN connection on roboRio.
The implementation of CAN on the RoboRIO only uses CANH and CANL. The RoboRIO has an integrated termination resistor.
Unread 10-12-2014, 16:02
Zentx's Avatar
AKA: Robert
FRC #3949
Would the 2 wires be able to fit the connectors, or should I use a different gauge wire?
Unread 11-12-2014, 03:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The roboRIO has 2 serial ports, but it also has a dedicated CAN interface, so you should certainly use that instead of the serial ports for controlling Jags.
Unread 11-12-2014, 07:51
The CAN connectors on the 2015 system fit 16 to 24 gauge wire.
Unread 11-12-2014, 11:25
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The JAGs have a built in RS232 port that is on the same receptacle as one of the CAN bus ports. Since the RoboRio has a CAN port you will not use the RS-232 port on the JAG. So yes, wire the Can H & L to the jags & ignore the RS-232 port on the Jag. Just like the Jags on the old system that was not directly connected to the Crio.
