Go to Post It's a process of elimination led by inspiration. - JaneYoung [more]
Unread 10-12-2014, 17:58
Axaileyer Axaileyer is offline
FRC #4110
Axaileyer is an unknown quantity at this point
Question How to program Sonar
Hey there ChiefDelphi, first post. Our team is trying to make a simple code that will turn our robot when it has a value of less than 10 inches. Anybody know how to (or a link to) coding sonar? first year team btw
Unread 11-12-2014, 08:16
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
Re: How to program Sonar
What program are you using to code your robot?
Unread 11-12-2014, 10:14
This is the LabVIEW subforum.
It depends on what sensor you are using and which input-analog, I2C, SPI, etc.
In general, you will measure the value returned by the sensor for 10 inches, then use a case statement that:
  1. Drives the motors forward while the value is greater than 10 inches
  2. Reverses the motor on one side when the value is 10 inches or less
Unread 07-01-2015, 10:05
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
http://imgur.com/A14Tgq0
This is always the code my team has used in order to get inches out of sonar, this is just off of memory.
If I remember correctly the sonar is wired for 12C
Unread 07-01-2015, 10:12
FRC #0144 (R.O.C.K)
Check out the examples under the help tab. They show you how to execute almost every function you could need on your robot ranging from drives to vision and sonar. All you need to do to use them is to drag and drop the vi after you open the example.
