Go to Post Wait, robot? We've been working on building a team. - ATannahill [more]
Unread 08-12-2014, 18:28
ebrnc's Avatar
ebrnc ebrnc is offline
FRC #4607
ebrnc is on a distinguished road
Ordering Materials
Quick question: how is the wireless bridge hooked up to the new RoboRIO? What kind of cable do we need? Also, are Weidmüller connectors needed for connections to the PCP? I heard this somewhere, but I am not sure if it is true or not. Thanks!
Unread 08-12-2014, 18:35
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Ordering Materials
Based on the image of the new control system the wireless bridge will be connected via USB. I imagine that the cable will be provided in the KOP
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 08-12-2014, 18:40
ebrnc's Avatar
FRC #4607
That would make sense. However, I do not think my team is choosing to receive the KOP this year. Hmmmmm.
Unread 08-12-2014, 18:43
The DLink, Rev B will be connected via the roboRIO Ethernet port.
Pretty much the same way it got connected on the older control system.
So you just need an Ethernet cable.
Power will come via the Voltage Regulator Module "5v/2a" Weidmüller connections.
That sample wiring diagram on the FRC Blog is out of date.
What's a PCP?
RamZ's Avatar
RamZ RamZ is offline
Project Manager & Driver
AKA: Ram Zallan
FRC #0004 (Team 4 ELEMENT)
RamZ will become famous soon enoughRamZ will become famous soon enough
I think you're mistaken, as the Kit of Parts is a tote with various parts that is given to every team every year at kickoff. Your team may have opted out of the KOP Drive Base, but that's a totally different thing.
Team 4 ELEMENT
team4element.com facebook twitter instagram
Unread 08-12-2014, 18:52
ebrnc's Avatar
FRC #4607
Awesome. Thank you! Haha whoopsies... Typo: PDP. And that makes more sense about the KOP I was unsure of what was included in the portion given to all teams!
Unread 09-12-2014, 07:56
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
The PDP has two different connections on it. For the traditional 40/30/20 Amp breakers, it uses the same connectors as we have previously.
For the Rio, and your first VRM & PCM, you use the Weidmüller connectors. The Weidmüller take bare copper and do not require anything to be crimped to it. That said, I recommend tinning the wires to prevent them from getting "mashed" after repeated insertions/removals.
Unread 09-12-2014, 08:09
EB,
The Weidmuller connectors are designed for wire or ferrule termination. It is not mandatory for the ferrules but they might make termination easier in a tight robot. Get very good at twisting the wire and inserting it on the first try. I suggest teams practice outside of the robot. 'No whiskers' should be your watchwords.
Unread 09-12-2014, 15:17
JCharlton's Avatar
Happy Birthday! JCharlton JCharlton is online now
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
I'd never used ferrules before, but after trouble inserting wires into the new PCM (particularly for the larger compressor wires) I ordered a kit from ferrulesdirect.com. Well worth it, much easier to work with and I'd guess more reliable too. If your team can afford it I'd recommend purchasing a crimping tool and ferrules.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 09-12-2014, 15:24
AdamHeard's Avatar
Lead Mentor
EB,
Which ferrules would you recommend.
Unread 10-12-2014, 08:19
Adam,
I don't have the Weidmuller part number but I wouldn't use anything else. Get the right crimper as well.
Unread 10-12-2014, 12:03
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
Having not seen the new control system can someone recommend a length for posts on the Weidmuller wire ferrules?
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
Unread 10-12-2014, 18:14
JCharlton's Avatar
AKA: JC
The recommended strip length is 8mm. This is quite long for strands, easy to get them bunched up.
Ferrules avoid all this. Another benefit is that with plastic collar ferrules it's easy to verify visually that all the wires have been inserted to the correct depth.
Unread 10-12-2014, 18:46
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Adam,
Here's the relevant information from this spec sheet. I believe that is the series connector the new control system uses.
With wire end ferrule, acc. to DIN 46 228/1, min. 0.25 mm²
With wire end ferrule, acc. to DIN 46 228/1, max. 1.5 mm²
w. plastic collar ferrule, DIN 46228 pt 4, min. 0.25 mm²
w. plastic collar ferrule, DIN 46228 pt 4, max. 0.75 mm²
I haven't used these connectors yet so I could be reading this wrong. From what I see it looks like many manufacturers make ferrules that meet those specs. Does that all look right Al?
Unread 11-12-2014, 11:44
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Al,
Given we all get $30 to spend at Inventables what are your thoughts on these ferrules and associated crimper for use with the new control system Weidmuller connectors?
