Go to Post Since the dawn of man, martial artists have sought to master fighting styles that seamlessly blend the attributes of strength, power, quickness, grace, and speed. You've heard them all. The Tiger. The Crane. The Mantis. Now witness.......The Nerd. - Travis Hoffman [more]
Unread 11-12-2014, 19:32
ThunderousPrime's Avatar
ThunderousPrime ThunderousPrime is offline
All Drive. No Drama.
AKA: Nick Brown
FRC #1511 (Rolling Thunder)
ThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to behold
1511 Prototype Drivetrain
Hello All,
1511 has been working on assembling a prototype drivetrain that utilizes Vex Pro Ballshifters Gearboxes and a pneumatically controlled drop down “belly pan.” Four pneumatic pistons can push the belly pan against the floor and raise our wheels off the ground. The bottom of the belly pan has wheel tread to increase the friction between the robot; the intent of the belly pan is to make the robot “unpushable” once the pan is dropped down.
Here is a link to an image gallery of the robot.
Here is a playlist of videos of the drivetrain driving.
2015: Montreal Regional Chairman's Award
2014: Finger Lakes Regional Chairman's Award, Tech Valley EI
2013: Boston Regional Winners with 125 and 126
2012: Connecticut Regional Engineering Inspiration Award
Unread 11-12-2014, 19:46
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: 1511 Prototype Drivetrain
Why have such a huge reduction off the ball shifter if your just going to multiply it in the last stage? Couldn't you just remove the external gear reduction ?
2016: FRC 865 Mentor
Unread 11-12-2014, 19:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Are those tensioners going to be okay? I've seen delrin/plastic tensioners used before, but not on #35 chain.
Very cool robot idea. Make sure that your electronics don't pop out when you
drop the base.
EDIT: YES! That robot is FAST! Fantastic. Beautiful. Your driver looks more than competent too.
Unread 11-12-2014, 20:00
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Just wondering, how much stress testing (at last years max weight) have you done with that belly brake system? Is it robust enough that you will start sliding before damage is done to your belly pan? Also, do you have a safety in case you lose pressure during a match?
Unread 11-12-2014, 20:05
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
IIRC, 1114 has used a similar chain setup in the past as far as tensioners and #35 chain. They use the biggest sprocket possible and nylon tube on a dead axle to act as tensioners that push on top of the chain in their sheet metal drive from 2013. Take a look if you have a chance. I did a lot of research on that bot and found a lot of the stuff they did to be quite simple and elegant.
Unread 11-12-2014, 20:30
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
drop the base.
As long as it isn't soft, or overly grippy plastic this type of tensioning system works well. As with any chain system, it will wear down over time and need to be replaced.
An example would be dirtbike chain guides
The material is akin to delrin or HDPE, and eventually wear out, but not before multiple hours of run time have passed in a much harsher environment than FRC
(2015-?): 973
(2012-2015): 955
Unread 11-12-2014, 21:52
Vespasian's Avatar
Vespasian Vespasian is offline
AKA: Elliot Dowd
Team Role: CAD
Vespasian is an unknown quantity at this point
We haven't done much actual stress testing yet, though we have had multiple people try to push it on carpet with the pan down to no avail (other than the carpet moving). This design has no safety factor in case of pressure loss, but for our build season design (if the game is conducive to this kind of base) we will more likely go with four dropping "feet" and a static pan. It was a cool idea, but I'm sure it scares our electrical mentors considerably.
I also plan to experimentally test how much of a factor surface area is in terms of tread traction. Conventional physics says surface area has no role in frictional force, but that only really applies for flat surfaces, not ones with grooves like the blue nitrile tread we used on the bottom.
Unread 12-12-2014, 11:36
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Pushing on it is quite different from getting nailed full speed by a 150 lb robot.
Unread 12-12-2014, 19:25
Vespasian's Avatar
AKA: Elliot Dowd
Team Role: CAD
Good point, we should test smashing into the drivetrain with the pan down using one of our previous robots.
Unread 12-12-2014, 20:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Make sure you have plenty of spare cylinders.
Unread 13-12-2014, 14:51
Vespasian's Avatar
AKA: Elliot Dowd
Team Role: CAD
I plan on buying some single action cylinders as well, probably in a decent quantity.
Unread 13-12-2014, 18:21
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
I love the tensioners.
Were I to design a drive like this, I'd personally forget about the omni wheels on the corners and use normal traction wheels. At high speeds with a square or slightly long frame, a 6 wheel dropped center drive turns a little on the fast side, even without omnis.
If you don't want to drop the center and want to use 4 traction + 2 omni's, that's cool too.
For an example of a drive which uses omnis to make it more manuverable than the average tank drive, check out 1625's 2014 drive. I heard that weight distribution is important for something like that , though.
I'd also eliminate the dropdown belly pan brake. It's a cool idea for a game where you really don't want to go anywhere, but, as I said in the other thread, I'd rather make sure I have high traction on my wheels and a way of locking them (encoders and smart code?) For a game where alignment (like, say, to shoot) is key, odds are a robot's momentum when it hits you will knock you far enough out of alignment that you have to switch back to wheels to realign.
Plus, "Our brakes are down and we can't move" is a bad way to end a match.
Unread 13-12-2014, 18:42
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
The drop down belly pan is a good idea. We had a "friction plate" on 340 last year.
The key is spring return cylinders in case of loss of air and another thing is don't lift your wheels off the ground. Have the plate push against the ground and as long as your wheels don't come up and the stroke on your cylinders is small enough >1" they will be fine under side load. Looks like a great drive train.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 13-12-2014, 18:47
Olin class of 2019
I'm curious- how much did your driver end up using it? I've always assumed that they wouldn't be too useful against a traction-limited drive.
