Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 11-12-2014, 20:18
RonHoof RonHoof is offline
FTC #9203
RonHoof is an unknown quantity at this point
[FTC]: Samantha Module Smoked and Burned Out?
We powered up to work on autonomous code and seem to have had an unusual Samantha module problem. As soon as I hit start on the FCS, the connection dropped and the Samantha module started smoking. Attached pic is the board. Charring is near the power (no surprise) and also the USB. Any ideas what we should look for as a cause?
Unread 11-12-2014, 21:10
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: [FTC]: Samantha Module Smoked and Burned Out?
No chance of putting the magic black smoke in there.
  • Any charring on the power connector or USB cable?
  • Any chance of a picture of the opposite side? Might be more informative.
  • Matrix or Tetrix?
  • Any USB surge protectors or Ferrite Chokes used?
I'd really like to find out what caused this to happen. I've seen a few die and internal parts die but NEVER like that.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 12-12-2014, 14:08
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
I have never seen this happen. thats actually really interesting. I have no clue what could of caused that.
Unread 12-12-2014, 14:20
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Was this the first use of the module? If so contact to see if you can get it replaced. We have done a lot of things to our Samantha and nothing has happened like this.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-12-2014, 20:02
FTC #9203
Thanks for the replies. It was used on Tetrix and this is its second season. Other side looks like new, date stamp is 2011. No charring on the cables or the ports. We use a surge suppressor (http://www.l-com.com/surge-protector...ith-pigtail-12) between the NXT and Samantha.
I think we have decided there must have been a short on the robot that put voltage on ground - Samantha went because it was the weakest link.
Rewired, shortened, tightened and isolated wherever possible. Working fine on the replacement module.
Thanks again,
Ron
