Go to Post Just think of the deadline as your six week deadline for FIRST, just when you think you can't do it, you are amazed by what you can do. - JackN [more]
Unread 11-12-2014, 20:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Our First Swerve
Interesting. The weight is quite high,, but the simplicity of this design is really good. Excellent, even, espcially considering that it's made in SketchUp. Look into getting some SolidWorks licenses for the team.
That being said, there are a few changes I would highly recommend:
1. Change the wheel to a single wheel in the center. Having such widely seperated wheels will contribute greatly to wheel "scrubbing" while turning.
2. Make those pulleys the correct diameter and width. Those look like 5mm wide belts right now or something, which is way too thin. Go with 9mm wide or 15mm wide belts.
What size box tubing is that? Can you source it? Do you have thrust bearings or thrust washers on there?
Unread 11-12-2014, 21:15
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
I give great credit for it not being derivative of other designs. Signaling independent thought. I also really like that this is a minimum required machining capability design - we look for that as a team that enjoys swerving but does not have much machining resources. This does tend to add weight.
I presumed what looks like belts is a crude rendition of chain and sprockets.
I do think having the two wheels, spread apart will cause a reduced response time for steering which I believe to be necessary for smooth transitions and driving experience
What size - diameter - colsons? 3.25"? probably fine with 1 CIM.
Nice addition to the swerve design discussions.
