Go to Post You can reduce the size of your wench. - ngreen [more]
Unread 12-12-2014, 01:40
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
[FTC]: Correct Samantha.hex File
I just noticed that there are two different Samantha.hex files available.
One is from the current FCS (...\Samantha Field Control System\Samantha) dated 9/9/2011.
Another is located in the latest LabVIEW folder (...\National Instruments\LabVIEW 2012\Targets\NI\NXT\NXTToolkit\Samantha) dated 11/21/2013.
Is there any difference? Should we be using the latest one. All the literature I've read the FCS version is the one to use.
Is there anything specific about the LabVIEW Version for LabVIEW robots?
Will a Samantha flashed with it cause problems with RobotC programs?
We are currently flashing all the Samanthas for our qualifiers with the FCS version of the file. I'm wondering if the later version has some improvements in it that are safe to use for robots programmed in any language.
Thank you,
Dan
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
Unread 12-12-2014, 08:50
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: [FTC]: Correct Samantha.hex File
I've always used the one in the Samantha Folder for setting up competition flashes. That is the correct one.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
