Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 12-12-2014, 15:25
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
Re: Encoders for 2015 Season
From our experience with the CUI encoders, we have had only a positive experienceso for. They seem to be more reliable becuase the actual disk is enclosed and magnetic, not optical. They and mount in a very similar way to the E4P, and could be used for a variety of similar uses.
We used E4Ps for our mechanum last year. Because they were hard to reach under the robot and thus even harder to install/replace during a breakdown, we will probably use all CUI encoders for future mechanum drives. BUT. Be warned:
"*We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time
and affect encoder performance."
....Its easy to exceed this recommendation if you are careful and treat the plastic tabs and axle mount nicely, but every time you do you risk damaging the disk inside and breaking the plastic mount.
How delicate is the magnetic disk anyways?
Mind, the encoders in the FIRST Choice are a little different then the ones in our picture from the OP, they are "straight radial" pins while the FC ones are "right-angle axial" ones.
