Go to Post There are times when we talk as friends and joke around about things like this, but then the most important times are when he says "I'm telling you this as a mentor," no matter what it is, those moments mean a lot. - Akash Rastogi [more]
Unread 12-12-2014, 18:10
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
A different water game, this one on my boat
I have a boat.
It has an engine that produces water at 170 degrees F after about 20 mins of use. The water temp starts at 50F and increases in a linear fashion until 170 and then levels off. The cold / raw sea water system kicks in and keeps the temp at 170 F
I have two water tanks, each holds 11 gallons of water
They have a 3/4 copper pipe in them, 6 feet long in a coil. The coolant water cycles through the tubing to heat the fresh water in the tank.
engine --> Tank 1 ----> Tank 2 --->  return to engine
If I start with 50 degrees F water in both tanks how long until the water reaches 120 degrees? I understand at some point both tanks will be at 170 degrees F, I'm interested in the 120 F mark.
If I replaced these two tanks by one tank that held 20 gallons and routed the water twice through the tank:
engine --> Tank Upper Loop ---> Tank Lower Loop --> engine return
How long would it take to get this tank up to 120 F?
(disclaimer: I have the boat, I've done the real world testing, so I know the answer to question 1 (two tanks). )
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 21-12-2014, 18:26
Kuhnahtt's Avatar
Kuhnahtt Kuhnahtt is offline
Elizabeth Knott
AKA: Elizabeth Knott
FRC #1261 (Robolions)
Team Role: Animator
Kuhnahtt is an unknown quantity at this point
Re: A different water game, this one on my boat
Math? On winter break? I can solve it easily, but I mean… Math?
