Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 13-12-2014, 08:18
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Back driving a CIM
Originally Posted by matthewdenny View Post
We are thinking about the possibility of a drive motor being only occasionally used, and freely spun by the gear box when not used for acceleration/pushing.
As long as you don't set it to brake mode this should not be a problem but acceleration and pushing make up almost all motion in an FRC match because by definition to change direction you must accelerate.
We also have a swerve design where to rotate the wheel 90 degrees it would have to back drive a cim a rotation or two.
In most (if not all) swerve drives that use bevel gears when the pod rotates instead of backdriving the cim the wheel turns slightly.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
