Go to Post An inability to communicate your ideas effectively is a handicap you would be well served to strive to overcome. - Ether [more]
Unread 11-12-2014, 21:54
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Encoders for 2015 Season
Hi guys. I have been looking for encoders for the new season and we typically use these from andy mark, but I was trying to find a cheaper and better overall option.
I know that some teams are experimenting with these new ones, but I was trying to see how people feel about them and then where to get them if they are nice.
Unread 11-12-2014, 22:41
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Encoders for 2015 Season
Had nothing but trouble with the US Digital encoders like the one you linked.
Years of trouble.
Many teams swear by them we simply can't have any more surprises.
DigiKey sells may fine encoders that are slightly more expensive.
If, like me, the time you waste playing with the encoders in the end is way more valuable than the encoder I would go shopping at the higher price.
One hour of my time more than buys all the encoders we are likely to need from a company like GrayHill.
Further it reduces this when someone suggests using an encoder.
Unread 12-12-2014, 12:18
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Years of trouble.
Our experience with the US Digital encoders is mixed. They work very reliably when handled and installed properly. But, as hard as we try, working with High School students, that is not always possible. Disk get dirty, smudged, and misaligned. Shaft run-out and end-play will destroy the little US Digital encoders in a heartbeat.
Don't misunderstand me, US Digital makes some fantastic encoders. It's the ones linked to by the OP that can be a bit suspect.
A sealed encoder that is mechanically isolated from motions that can damage it are your best bet.
Unread 12-12-2014, 12:50
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
We have never used the ones linked in the OP, but I did mount a couple for a preseason project and didn't like them at all. Too many things to go wrong. I like these:
http://www.usdigital.com/products/en...otary/shaft/S4
We get the ball bearing version and have never had a failure. Some have been around for a number of years. I don't like the tiny wires and connectors, those do fail and need to be replaced. They're easy to mount and we just hook to the shaft with snug fitting surgical tubing. They are pricey, but as mentioned above, I get that back in time not messing with them and we use them over and over.
We will also test the ones we got with FIRSTChoice. I prefer encoders with a shaft, but the price is better and they look like a good compromise.
Ivan
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Unread 12-12-2014, 12:56
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We use the E4P every year, on our drive at least. In 2012 and 2013 we have also used them on our flywheels for shooting as well, with a lower CPR encoder disc. In 2012, we did have some issues with bad readings, but it was because of scratched old encoder discs rather than the encoder itself. (Hooking up a logic analyzer showed what was going on the signal when code wasn't behaving as expected.)
Most other issues we have during testing is usually due to an old encoder unit that has more than done its time. Whenever we use new, well handled units we seem to have no trouble. Having said that, everyone is also taught how to handle them and is careful with them.
US Digital has discontinued the E4P though (last year), and has just recently released the E4T as a replacement, so they will be interesting to try out.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 12-12-2014, 15:25
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
From our experience with the CUI encoders, we have had only a positive experienceso for. They seem to be more reliable becuase the actual disk is enclosed and magnetic, not optical. They and mount in a very similar way to the E4P, and could be used for a variety of similar uses.
We used E4Ps for our mechanum last year. Because they were hard to reach under the robot and thus even harder to install/replace during a breakdown, we will probably use all CUI encoders for future mechanum drives. BUT. Be warned:
"*We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time
and affect encoder performance."
....Its easy to exceed this recommendation if you are careful and treat the plastic tabs and axle mount nicely, but every time you do you risk damaging the disk inside and breaking the plastic mount.
How delicate is the magnetic disk anyways?
Mind, the encoders in the FIRST Choice are a little different then the ones in our picture from the OP, they are "straight radial" pins while the FC ones are "right-angle axial" ones.
Unread 12-12-2014, 16:20
mman1506's Avatar
mman1506 mman1506 is online now
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
I can't stand the tiny little connectors on us digital encoders, they always broke on us. I much prefer the solder terminals on other encoders like greyhills.
2016: FRC 865 Mentor
Unread 12-12-2014, 16:23
Jared's Avatar
Jared Jared is offline
The E4P (us digital) encoders are okay if installed properly. The S4 series with ball bearings are far superior.
My favorite encoders are the greyhill ones. They're more expensive and a tiny bit larger, but they are quite strong. You should have no problem putting a sprocket/pulley on the end of the shaft. You'll gain a lot of reliability and a much larger margin of error for relatively insignificant losses.
Unread 12-12-2014, 17:20
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
FRC #0449 (Blair Robot Project)
hzheng_449 will become famous soon enough
We use the US digital H6 encoder
The extra cost vs the E4P is definitely worth is as the H6 is more reliable and easier to use than the E4P.
Unread 12-12-2014, 19:08
Ben Wolsieffer Ben Wolsieffer is online now
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
What are the mounting options for the CUI AMT-10 encoders (like the ones mentioned above and included in FIRST Choice)? Has anyone tried using them with Andymark or VexPro gearboxes (specifically Touchbox Mini or 3-CIM ball shifter)?
I know I could do more research into the technical documents, but I'd like to hear people's experiences too.
Unread 12-12-2014, 19:10
AdamHeard's Avatar
Lead Mentor
I'm a big fan of US Digital, and use the super high count E6's where it makes sense... but for a shaft based option I'm not seeing the advantage of the H6 over the grayhill encoders. Much more money and size!
Unread 13-12-2014, 02:41
Twins Inc.'s Avatar
AKA: Zach Larson
I think that might be the best option right now, researching the spec sheets. I haven't seen the CUI encoders before this year, and I haven't really seen teams use them on those gearboxes yet. But hey, Prove me wrong! I'll get back here and let you all know what I find if I do eventually research this myself.
Unread 13-12-2014, 03:27
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Which grayhill model do you use and where do you source them?
Unread 13-12-2014, 08:13
mman1506's Avatar
no team (WARP7)
The grayhill 61K, 61E, 63R are the series commonly used in frc. They can be purchased from digikey.
Unread 13-12-2014, 10:13
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Are there any good options for measuring off the back shaft of a banebots style motor? Mainly common FRC encoders than can do 20,000 RPM and if there are any known good mounting options/tricks.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
