Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 13-12-2014, 10:56
AdamHeard's Avatar
Lead Mentor
Re: Encoders for 2015 Season
Originally Posted by nathannfm View Post
Are there any good options for measuring off the back shaft of a banebots style motor? Mainly common FRC encoders than can do 20,000 RPM and if there are any known good mounting options/tricks.
By the time you have any meaningful reduction off it the precision will be poor due to backlash for average FRC gearing. This could be acceptable for the application or a huge pain.
Unread 13-12-2014, 14:28
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Right, thanks for pointing that out, so no good for 100:1 VP on a swerve drive. We tried reading a shoulder bolt sticking out of the tapped hole but the tolerance on on that hole is non existent and it wobbled all over the place. Guess we are going to have to press a pin in and turn it to round after its in the shaft.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 14-12-2014, 11:47
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Originally Posted by mman1506 View Post
The grayhill 61K, 61E, 63R are the series commonly used in frc. They can be purchased from digikey.
Excuse my lack of experience - we have never used encoders, and I desperately want to this year. The Grayhill models referenced above look like potentiometers, for lack of a better description...How are they installed? Do you just couple the shaft to the gearbox shaft?
I understand how the US Digital one's install - in fact, we installed a pair on our robot this fall for the off-season, but never figured out how to wire them up or program them.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 14-12-2014, 12:37
Jared's Avatar
Jared Jared is offline
They're installed just like potentiometers, but they have no restriction on how far they can turn. If you want, you can couple them to a gearbox shaft, or you could put a sprocket or pulley on the encoder shaft.
To couple the shaft of the encoder to the gearbox without having to buy/make a shaft coupler, you can actually use a short piece of surgical tubing, and stick the two shafts inside the hole in the middle of the tubing and put on a few zip ties to prevent it from sliding out.
Unread 14-12-2014, 12:38
mman1506's Avatar
mman1506 mman1506 is online now
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
You are correct, they interface mechanically exactly like a pot would. Here is a pic of two grayhills 971 has on their bot https://lh6.googleusercontent.com/-f...52841%2529.JPG .
What's really great about the greyhills is that the shaft is supported by a ball bearing so they are MUCH more tolerable tolerable to axial and radial load than the commonly used US digital encoders.
2016: FRC 865 Mentor
Unread 14-12-2014, 13:19
Two things:
1) It's spelled "Grayhill", with an "a". (It's easier to find if spelled correctly)
2) Not all models of Grayhill encoders have ball bearings. Make sure to check the datasheet before ordering.
Unread 14-12-2014, 13:30
mman1506's Avatar
no team (WARP7)
Two things:
All of the models I previously listed and referenced to in my post are ball bearing supported.
Unread 14-12-2014, 14:00
I should have been clearer: The caution clarification was for other readers.
The specific post I responded to had no list and no reference.
Unread 14-12-2014, 14:22
AdamHeard's Avatar
Lead Mentor
Us digital does have shaft based encoders as well.
Unread 14-12-2014, 22:27
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
I'm a big fan of US Digital, and use the super high count E6's where it makes sense... but for a shaft based option I'm not seeing the advantage of the H6 over the grayhill encoders. Much more money and size!
Hey Adam would you mind linking me to your preferred grayhill encoder.
Many thanks.
Unread 05-01-2015, 22:51
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
Originally Posted by Twins Inc. View Post
From our experience with the CUI encoders, we have had only a positive experienceso for. They seem to be more reliable becuase the actual disk is enclosed and magnetic, not optical. They and mount in a very similar way to the E4P, and could be used for a variety of similar uses.
We used E4Ps for our mechanum last year. Because they were hard to reach under the robot and thus even harder to install/replace during a breakdown, we will probably use all CUI encoders for future mechanum drives. BUT. Be warned:
"*We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time
and affect encoder performance."
....Its easy to exceed this recommendation if you are careful and treat the plastic tabs and axle mount nicely, but every time you do you risk damaging the disk inside and breaking the plastic mount.
How delicate is the magnetic disk anyways?
Mind, the encoders in the FIRST Choice are a little different then the ones in our picture from the OP, they are "straight radial" pins while the FC ones are "right-angle axial" ones.
mecanum*
Unread 12-01-2015, 20:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
What specific Grayhill encoder is best to purchace from Digi-Key for a drive using a Talon SRX?
Unread 13-01-2015, 00:31
wmarshall11 wmarshall11 is offline
FRC #2399
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
I'm a fan of the 63R Series. Specifically, the 63R128 and 63R256 are good picks.
Unread 13-01-2015, 01:10
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
I don't know if there is a specific encoder that works *better* with the SRX than any other. That said, as in the post above the Grayhill 63R-xxx series has been the most reliable encoder Team 955 has ever used.
(2015-?): 973
(2012-2015): 955
Unread 13-01-2015, 08:11
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Word of caution about absolute encoders with the Talon SRX... most of them that provide analog output seem to require 5v power instead of 3.3v power which the Talon SRX must have for analog input. DO NOT connect 5v to the Talon's analog in. It might not end well.
CTRE is releasing a converter board and we are making some custom ones. We have a student working on a write-up of how we created ours along with details.
It might be neat to see the Talon SRX controllers support gray code in the future in addition to analog output for absolute encoders but that would likely require a firmware update and some serious coding witchcraft for the Talons.
