Go to Post We treat productive freshmen the same way as everyone else. As for excesively ambitous new people, we have one rule:what happens in the hotel, stays in the hotel... ;) - Crop-Circles [more]
Unread 12-12-2014, 16:00
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Back driving a CIM
Does anyone know how much torque it takes to back drive an unpowered cim motor? Does it mater if it is connected to a speed controller or not if the motor is programmed to 0?
Unread 12-12-2014, 16:05
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Back driving a CIM
Look up the cim specs on Andymark. All torques etc. are listed there.
Look for "torque at stall current".
Unread 12-12-2014, 16:14
FRC #6054 (Dukes)
I don't want the torque at stall current. I'm trying to find the torque at zero current. That number does not appear to be listed.
Unread 12-12-2014, 16:17
Jared's Avatar
Jared Jared is offline
It doesn't take very much to backdrive an unpowered CIM at low speed. To get the motor going quickly takes some more torque.
This information isn't on the datasheet.
If the speed controller is in brake mode and it receives a command of zero, it will short together the motor output. The current generated by the motor works to oppose the rotation of the shaft making it harder to backdrive. If the speed controller isn't in brake mode, it won't affect the CIM at all when it is command to zero power.
What are you looking to do with a CIM motor?
Unread 12-12-2014, 16:22
Nyle's Avatar
Nyle Nyle is offline
FRC #0422 (The Mech Tech Dragons)
Nyle is just really niceNyle is just really niceNyle is just really niceNyle is just really nice
I think he's asking how much torque it takes to spin a CIM that is not receiving any voltage, which would not be the stall torque. I don't see this anywhere on the datasheet for the CIM, although it might be possible to calculate it from data in there. Unless someone on here has already measured it and has the value available, you'll probably have to just measure it yourself. I'm not sure if connecting it to a speed controller would change the value or not, I believe that would depend on if/how the motor leads are electrically connected when the controller is set to zero. I'd guess that they are not, but I don't know exactly how they work. What do you need this for? For most cases I can think of where you might need it, approximating it as zero would probably not make any significant difference.
Unread 12-12-2014, 16:41
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Free speed drag torque for a CIM can be calculated based on data sheet parameters as follows:
Free power at 12V = Free current x 12V = 2.5A x 12V = 30 Watts
Effective resistance = 12V / Stall current = 12V/130A = 0.092 Ohm
Winding loss at free current = 0.092 Ohm x (2.5A)^2 = 0.57 Watt
Drag power at free speed = Free power - Winding loss = 29.4 Watt
Drag torque at free speed = 29.4 Watt / (5300 RPM x pi/30) = 0.053 Newton-meter
I can confirm from measurements in my motor lab that this theoretical figure is pretty close to what we really get, after the motor warms up a bit. Initially the drag (and the free current) are a bit higher because the grease and the brushes are a little stiff when cold.
Back to the OP: yes it matters a lot if the motor is connected to a speed controller. The calculations above give drag at zero current; when the CIM is connected to a speed controller its induced voltage (back-EMF) will excite the controller and that excitation will cause current to flow, charging up the controller's capacitors and creating additional drag torque. Anyone who has pushed an FRC robot and seen the little LEDs come on knows what I mean.
Richard Wallace
since 2003
Unread 12-12-2014, 22:35
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Relating to the op's question, would disabling 1 motor in a 3 cim gearbox and continuing to power the other 2 cause any damage to either the speed controller on the unpowered cim, or the unpowered cim itself? An example of a practical application for this would be in a 6 cim drive, if the current draw exceeds a certain amount, disable one motor on both gearboxes to lower the overall current draw.
Unread 13-12-2014, 08:08
FRC #6054 (Dukes)
We are thinking about the possibility of a drive motor being only occasionally used, and freely spun by the gear box when not used for acceleration/pushing.
We also have a swerve design where to rotate the wheel 90 degrees it would have to back drive a cim a rotation or two.
We would like to know how much torque it takes to do this. Also is the torque required the same regardless of the speed of rotation?
In both cases the coma would be hooked up speed controllers, but not receiving voltage from them.
Unread 13-12-2014, 08:18
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
As long as you don't set it to brake mode this should not be a problem but acceleration and pushing make up almost all motion in an FRC match because by definition to change direction you must accelerate.
In most (if not all) swerve drives that use bevel gears when the pod rotates instead of backdriving the cim the wheel turns slightly.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 13-12-2014, 14:18
brndn's Avatar
brndn brndn is offline
AKA: Brandon
brndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nice
In this case, aren't you powering the motor? I'm assuming the swerve module causes the wheels to rotate a little and you want to counteract that by powering them in the opposite direction.
