Thread Tools |
Rating:
Display Modes |
Re: CAD File Naming Convention
I had not previously heard of GrabCAD but their website looks pretty interesting. Have you used them before? Do they have a student version or do you use a paid plan?
As for naming conventions, they can very quite a bit. A lot of teams use a combination of their team #, the year, a sub-assy reference, and a part #. We would add initials of the creator so everyone knew who "owned" the part. Sometimes they just get named with a description. A good way to see what other teams do is to download their CAD files and have a look at all the part numbers that make up the assembly. |
http://www.team254.com/documents/partnumbers/
This is what we use. We will be modifying it this year to contain more information about what the part actually is, but the numbering will still be retained. All part numbers get checked out of a part management system when a part is created, to ensure continuity. Last edited by Cory : 15-12-2014 at 13:58. |
When I was on 1687, we used 1687-YYYY-SSM-M-xxxx -- description. For example: 1687-2014-SPS-S-0041 -- rear 3d gusset. We will likely be bringing this system to 5400 this year.
YYYY: year SSM: A three letter code indicating subsystem. The folder hierarchy used meant that in each folder, every part would share the same subsystem. M: A one letter code indicating the initial manufacturing technique used for the part. Other special identifiers included "A"for assembly and "C" for COTs, xxxx: a four digit unique identifier (really could have been 3, or even 2 digits) description: a concise descriptor of the part's role or design. The order worked well, since when sorted alphabetically, it would automatically filter by manufacturing technique If I recall, this was closely derived from 148's system. We were also quite meticulous about keeping drawing files and part metadata up to date, so that information such as designer, quantities, materials, etc. would remain up to date and easily accessible in our title blocks. Last edited by Joe G. : 15-12-2014 at 12:27. |
We add a description after the part number in the file name. This helps when you are trying to read the assembly tree and find a part. 971-14-A-0400_Octagonal Drivebase.sldasm 971-14-P-0020_Center Axle Holder.sldprt 971-14-P-0031_Belly Pan.sldprt We also revision our drawings when we send them out, and check in all drawings sent out for manufacture to our repository. That way, when a sponsor gives us a part back, we know exactly which drawing it was manufactured to. 971-14-P-0002-A_1in Wheel Rim.PDF 971-14-P-0002-B_1in Wheel Rim.PDF |
I should also note that our team uses a custom SolidWorks template that has custom property fields to fill out (such as part description). When that is filled out, you can set up Workgroup PDM to display it alongside the filename (as well as who has it checked out).
