Go to Post "It is a guaranteed fact that at least one rookie team will name their robot 'Chuck Norris'." - Tim Arnold [more]
Unread 15-12-2014, 17:45
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
S4 and MAE3 encoders..,. What?
I've been looking at the S4 and the MAE3 encoders from US digital and I have no idea how that thing should be placed in the robot. How does it physically connect to anything? Where do you put them? Am I being dumb?
Unread 15-12-2014, 17:53
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: S4 and MAE3 encoders..,. What?
The S4 is panel mounted, meaning that you insert the threaded boss through a hole, and secure with the included nut. From there, you can link the shaft to your robot through any number of means, including a shaft collar, surgical tubing link, or simply pressing or gluing it in a hole in your shaft. If you've been using the E4P encoders before, you won't be able to directly drop in an S4, but rigging something up shouldn't be too tricky.
Unread 15-12-2014, 18:04
FRC #6054 (Dukes)
so does it mount such that the end of the encoder is in line with the axle, or do you connect it with a belt?
What is a surgical tubing link?
Does anyone have pictures of these on their 'Bots?
Unread 15-12-2014, 18:22
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
2016: FRC 865 Mentor
Unread 15-12-2014, 18:35
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Simple answer, yes! Either way works. It will depend on your system's design. It could be directly in line, or parallel to the shaft. Belt linkages work as well as chain. The are things to consider with either approach. Putting too much tension on the encoder's shaft could be a problem and damage it. Not enough tension could cause slop and produce inaccurate measurements.
Sorry I don't have an actual picture, but with a bit of imagination you can see where a piece of surgical tubing stretched over both shafts here would make a fairly decent coupling. It would allow for a small amount of misalignment between the shafts as well.
The encoder in this picture has ball bearing shaft supports and practically zero rotational friction.
Unread 15-12-2014, 18:47
FRC #6054 (Dukes)
In the second picture how is the encoder connected to the shaft?
Also doesn't the surgical tubing cause cause the encoder to not reliably show the angle of the shaft?
Unread 15-12-2014, 19:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Generally you use the surgical tubing method for incremental encoders unless I am mistaken, so the error is minimal.
For the MA3, you stick it into a 3/8" hole and screw the nut onto teh threads to keep it in place. Then you stick into a hole at the end of a shaft and set screw it tight.
Unread 15-12-2014, 19:43
Why is the error minimal with incremental encoders but not absolute ones?
Unread 15-12-2014, 19:44
Joe G.'s Avatar
AKA: Josepher
There's practically zero resistance from the encoder, so the surgical tubing doesn't twist any appreciable amount.
Unread 15-12-2014, 19:48
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Becuase in the drivetrains above, the encoder is spinning at a rapid speed.
For the purposes of a swerve drive or arm, an absolute encoder would be spinning very slowly by comparison. Would that be correct?
Unread 15-12-2014, 19:58
1) There's no reason why an incremental encoder cannot be used in a slow-spinning application.
2) Properly designed and implemented, surgical-tubing shaft couplers can successfully be used in some high-speed applications.
Unread 15-12-2014, 20:48
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
True. I'm sorry, I phrased my statement wrong, because I am used to fast-spinning incrementals on drivetrains.
I totally agree with #2. I'm saying that's a better application for it, although apparently that's not the case due to the negligible resistance of the encoder.
