Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 11-01-2002, 12:05
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Yaw rate sensor (gyro for the layperson)
Has anyone come up with a decent use for the gyro this year?
Personally, I think it would be cool if a team used it to control a holonomic base (can move or spin in any direction). So that the operator didn't have to put himself in the Robot's frame, just point the joystick in the direction that he wanted the Robot to go. But that's not necessarily specific to this game.
Unread 11-01-2002, 12:34
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Possible Gyro Use this year:
Ballast....
haha
Unread 12-01-2002, 23:38
Skanker's Avatar
Skanker Skanker is offline
#0498 (R.P.M)
Skanker is an unknown quantity at this point
Send a message via ICQ to Skanker
as cool as that would be (thinking of an orb-bot), it would, in this game be useless. anyway, I don't think there really *is* a purpose for it at all this year... unless you have an arm or something whose yaw rate you want to sense?
-Sean Rice
Cactus Robotics Club Alumni
Unread 13-01-2002, 09:27
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
MANY teams use the yaw rate sensor to compensate between the two sides of the robot so that the machine will stay going in a straight line.
We have used in on a number of machines. It works very well. A machine that tends to spin into a "death spiral" can be made into a pretty well behaved machine with feedback from the yaw rate sensor.
Joe J.
Unread 14-01-2002, 00:41
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
One of our mentors in convinced that we can build a two-wheel-drive segway to solve our turning radius problems with the gyro chip. However, we tend not to take that mentor that seriously .
Zan Hecht
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
