| Thread Tools |
Rating:
Display Modes |
#166
Re: VEXpro 2015 Product line launch
Regarding the new 1/2" hex VersaHub, is the new one just smaller and lighter and less expensive or is there something more meaningfully different?
PN 217-4009 - new product PN 217-2592 - older product http://www.vexrobotics.com/vexpro/mo...versahubs.html If I recall, on the old ones the hex was not consistently clocked relative to the bolt pattern, so it wasn't possible to use two of them on one wheel. Instead you'd need to use one plus a hex bearing held in place with screws. I'm hoping this is what is different and the new ones, so that two can be used on a wheel and the hex flats all line up. |
#167
Hmm... do I spy a barrage?
#168
There does not appear to be a "light duty" designation for the plastic hub. Do you have any information on it's limitations? I'm wondering if using a pair of these on a 4" Traction Wheel would be an acceptable setup for a drivetrain. |
#170
You can always tap for a #10-32 heli-coil, threaded insert. I'm a #10 and #8 guy. If I had to use 1/4", it would be 1/4-28.
Why the fine threads?
#173
Personally, I'd be less worried about breaking the hub apart and more worried about gradual wear along the corners of the hubs leading to backlash.
#174
I agree, that is likely to be the first sign of a problem with these hubs. We used some .09 5052 versa hex hub stand ins on our practice bot and for part of an event on our competition bot and we rounded some of the corners and started getting a lot of backlash.
#175
I'm confident that VEX did their testing. I was just saying that I would think that would be the initial failure mode over completely breaking the hub. I could also be very wrong.
#177
Just a habit of working on aircraft. The robots are vibration machines, so any little advantage to screws backing-out I will take. We have quite a few fastener stores in the area, so access to fine thread fasteners is not an issue.
That being said, we haven't used a 1/4" fastener on the robot in quite sometime - maybe a COTS component that required. We have used #10 rivet nuts in 1/4" holes in the past in the KOP frames. |
#178
I don't think we have 1/4"-28 screws, just tons of 1/4-20", 10-32, 8-32, 6-32, and some metric. |
#179
Arguably the most standard FRC fasteners next to a philips head #6-32. |
#180
