Go to Post Good luck, and may the FIRST be with you. - Leav [more]
Unread 17-12-2014, 16:40
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Does anyone here use IntelliJ as a compiler?
I've used netbeans for all my stuff in java since I learned java, and well, i guess most people are switching to Eclipse so I better learn eclipse - but that's unrelated.
Was wondering if anyone has gotten the libraries and whatever to work in IntelliJ, i've heard some good things about the program and i'm hoping I can try it out in 2015 (since if netbeans and eclipse are nearly the same, and IntelliJ is well-regarded, then maybe IntelliJ is better than eclipse... i dont really have the best reasoning, just go with it...)
