Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
  #166   Spotlight this post!
Unread 17-12-2014, 15:35
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: VEXpro 2015 Product line launch
Regarding the new 1/2" hex VersaHub, is the new one just smaller and lighter and less expensive or is there something more meaningfully different?
PN 217-4009 - new product
PN 217-2592 - older product
http://www.vexrobotics.com/vexpro/mo...versahubs.html
If I recall, on the old ones the hex was not consistently clocked relative to the bolt pattern, so it wasn't possible to use two of them on one wheel. Instead you'd need to use one plus a hex bearing held in place with screws. I'm hoping this is what is different and the new ones, so that two can be used on a wheel and the hex flats all line up.
  #167   Spotlight this post!
Unread 17-12-2014, 15:36
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Hmm... do I spy a barrage?
  #168   Spotlight this post!
Unread 17-12-2014, 15:38
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The new one is plastic so it's designed for lighter duty applications. At one point VEX started making all their Hex hubs aligned to the versakeys and I'm betting they still are, the plastic ones will definitely be aligned since they are molded. At one point they had to rotary broach some of their plain bore hubs to meet demand and those weren't aligned.
  #169   Spotlight this post!
Unread 17-12-2014, 15:48
craigboez's Avatar
Mechanical Engineer
I guess I didn't look close enough. Never having purchased one I assumed all of these were plastic.
There does not appear to be a "light duty" designation for the plastic hub. Do you have any information on it's limitations? I'm wondering if using a pair of these on a 4" Traction Wheel would be an acceptable setup for a drivetrain.
  #170   Spotlight this post!
Unread 17-12-2014, 15:51
Andrew Lawrence
Posts: n/a
I would say that the original aluminum would be better for drivetrain and other high load applications. These new plastic ones would work well in things like intakes where there isn't a lot of torque trying to break the hub apart.
  #171   Spotlight this post!
Unread 17-12-2014, 16:31
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
You can always tap for a #10-32 heli-coil, threaded insert. I'm a #10 and #8 guy. If I had to use 1/4", it would be 1/4-28.
I'm Mr #10. It's my favorite fastener, and we've used it forever.
That being said, the more COTS teams are in 1/4-20 land. This makes sense.
Being Mr #10, I'm STOKED about the hole as we'd never use a bolt to retain the items on a shaft... but these will make great heavy duty standoffs with the hole already drilled.
ThunderHex is my favorite new product, and I think they did it perfectly. Now time for 3/8" thunderhex next year
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #172   Spotlight this post!
Unread 17-12-2014, 16:36
Engineering Coach
Why the fine threads?
  #173   Spotlight this post!
Unread 17-12-2014, 17:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Personally, I'd be less worried about breaking the hub apart and more worried about gradual wear along the corners of the hubs leading to backlash.
  #174   Spotlight this post!
Unread 17-12-2014, 17:06
Engineering Coach
I agree, that is likely to be the first sign of a problem with these hubs. We used some .09 5052 versa hex hub stand ins on our practice bot and for part of an event on our competition bot and we rounded some of the corners and started getting a lot of backlash.
  #175   Spotlight this post!
Unread 17-12-2014, 17:19
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
If that is the case, I would assume that it could be a problem on the colsons with the molded hex hubs as well.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #176   Spotlight this post!
Unread 17-12-2014, 17:32
Engineering Coach
I'm confident that VEX did their testing. I was just saying that I would think that would be the initial failure mode over completely breaking the hub. I could also be very wrong.
  #177   Spotlight this post!
Unread 17-12-2014, 17:47
tim-tim's Avatar
AKA: Tim Miedzinski
Just a habit of working on aircraft. The robots are vibration machines, so any little advantage to screws backing-out I will take. We have quite a few fastener stores in the area, so access to fine thread fasteners is not an issue.
That being said, we haven't used a 1/4" fastener on the robot in quite sometime - maybe a COTS component that required. We have used #10 rivet nuts in 1/4" holes in the past in the KOP frames.
The RoboBees
  #178   Spotlight this post!
Unread 17-12-2014, 18:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
An advantage to 1/4"-20 is that more teams that I know of stock it over 1/4"-28. Something to consider as well.
I don't think we have 1/4"-28 screws, just tons of 1/4-20", 10-32, 8-32, 6-32, and some metric.
  #179   Spotlight this post!
Unread 17-12-2014, 18:20
AdamHeard's Avatar
Lead Mentor
Every single FRC team in the last 10+ years has had at least two 1/4-28 nuts on their robot.
Arguably the most standard FRC fasteners next to a philips head #6-32.
  #180   Spotlight this post!
Unread 17-12-2014, 18:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
True, unless one student removes them and another replaces them with 1/4-20 nuts. Now that team has intermittent electrical problems as well.
