Go to Post why would someone do that? Go on the internet and tell lies? - MaGiC_PiKaChU [more]
Unread 17-12-2014, 19:54
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
paper: New Control Functions - Drive System Testing
Thread created automatically to discuss a document in CD-Media.
New Control Functions - Drive System Testing by Chris Fultz
Unread 17-12-2014, 19:59
Rookie Year: 1942
Re: paper: New Control Functions - Drive System Testing
As part of our beta testing, we used the roboRIO for some drive system evaluation testing, capturing data not available through the 2014 control. We were testing 2, 4 and 6 CIM and 4 CIM+2mini-CIM drives and capturing data, including amperage and voltage.
Through this testing, we identified an operational effect of one of the control features that we felt would be good to share.
The new control disables output to the PWMs when the system voltage drops below 7V. This is a good feature as it helps keep the control and radio on-line.
However, operationally, this can cause the PWMs to cycle off and on as voltage recovers and then reduces if no change is made by the operator. Depending on the situation - pushing, lifting, etc. - the effect on the robot may be a non-event or may create a response that needs to be managed with software or by operator actions.
The attached paper describes the specific testing we were doing, and the results. It includes 2 charts that show graphically what was occurring.
As teams prepare to use the new control for 2015, we thought this was an interesting and different control response that would be worth sharing.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-12-2014, 07:56
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Good information to know. Thanks.
Unread 18-12-2014, 08:03
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Thank you for sharing this. I noticed that the paper only refers to the two CIM configuration. What were your results when testing the various other combinations you mentioned above?
Unread 18-12-2014, 11:24
Michael Hill's Avatar
Thanks a lot for sharing this. This is pretty interesting, and could potentially cause a lot of headaches for teams that run 6-cim drivetrains in high gear. I only have theoretical calculations, but it appears that if you have a fully loaded robot (weight-wise), and run in high (fast) gear, you could potentially not even start. I'm using my drivetrain calculator (available as a white paper), and looking at a gear ratio of 4.63:1, 4 inch wheels, and a battery voltage of 12.8V (typical of a mid-match voltage) (Note: this is the default setting for my drivetrain simulator). From a stop, it looks like the battery voltage could drop down to 6.67V if the robot were commanded to go full forward. Again, this is all just a simulation that has absolutely no guarantee of correctness, but if possible, I'd love to see if this causes problems in reality.
Unread 18-12-2014, 11:42
Rookie Year: 1942
We only did this specific test with the 4 CIM configuration because with 6 CIMs or 4+2 we just spun the wheels.
The full paper has data on 2, 4, 6 and 4+2 configurations for basic acceleration and for pushing another robot (130 pounds). We are still a few days away from publishing that.
Chris Fultz
Unread 18-12-2014, 11:48
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Out of curiosity, does this affect CAN controlled controllers? Or just PWM?
Unread 18-12-2014, 12:03
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
My understanding from last night's GameSense is that the load shedding that occurs at 7v impacts all speed controllers, no matter how interfaced.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 18-12-2014, 12:40
It would also be interesting to see if SPI cut out as well.
Unread 18-12-2014, 13:03
Volunteer, WPILib Contributor
no team (Waiting for 2021)
This worries me. I know during hard acceleration at IRI with our 6 CIM Drive we got below 7 volts. I'll have to look at our logs and see how often we actually dropped blow.
Team 4488 - Mentor 2013-2016
Unread 18-12-2014, 13:07
SPI should function until the battery voltage drops too low for the roboRIO's 5v supply to be maintained. The brownout "load shedding" is a software function that explicitly turns off pneumatic solenoid valves and motor speed controllers when the battery voltage falls below a certain threshhold. It is done in order to try to prevent the voltage from dropping further and causing a complete loss of the control system.
Unread 18-12-2014, 13:09
How would that be implemented with a CAN connection without affecting other non-motor CAN devices?
(I could guess, but if anyone knows where this is documented would you please post a link)
Unread 18-12-2014, 13:10
Consider this an opportunity to do dynamic power management. You can monitor battery voltage and motor currents, and you should be able to come up with a way to keep the voltage from sagging low enough to trigger the automatic brownout.
Unread 18-12-2014, 13:20
Yeah were probably going to look into doing something like this. I'm glad they added current monitoring this year.
Unread 18-12-2014, 14:18
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Here's the graphic from last night's Behind The Lines showing the key battery voltage points and what happens when they're reached.
NOTE: This is different from what was shown during the episode, and is more accurate.
The BTL episode can be viewed here: https://www.youtube.com/watch?v=uUYlS2Vkyuo
