Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 18-12-2014, 09:57
VladimirM's Avatar
VladimirM VladimirM is offline
Robot Captain
FRC #5631
VladimirM is an unknown quantity at this point
VersaFrame by VEX Robotics
Hi everyone,
I've been looking at the Vex pro VersaFrame. Has anyone had success with it previously? Seems like a good deal at around $20. Just seeing your opinions on it before purchasing.
Thanks,
Vladimir Milicevic
Team 5631 Robot Captain
Unread 18-12-2014, 10:02
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: VersaFrame by Vex Robotics
We used it last year after we decided c-channel just wasn't going to cut it any more. The 2x1 worked absolutely fabulously for the frame; we assembled it with their gussets and didn't have a single problem. All the cutting was done (inaccurately) on a chop saw since it was all we had then and the gussets took care of the alignment for us.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 18-12-2014, 10:11
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We used it extensively in the 1x1 configuration last year. The thin stuff is too weak to stand up to FRC but they've come up with a thicker version this year that we plan on using. We built a WCD in the off-season using the 2x1 and it works great. We plan on building much of the 2015 bot with the stuff. Really great!
Unread 18-12-2014, 10:24
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
FRC3005 had success with it last year as well.
A few points:
The gussets and holes are helpful, but things still can move around a little bit prior to riveting. Especially for drivetrains, I think it is worth the extra effort to make sure everything is built on a nice flat table (check it) and properly squared up prior to starting to rivet.
Watch how you use the gussets. Rivets and gussets are stronger in the shear direction of the rivet. If you are putting the gussets in bending against the 1/8" dimension and pulling on the rivets, you invite failure modes.
Don't underestimate the accuracy of what you can get with a chopsaw. The human eye is capable of resolving very fine dimensions if you have a good reference point. I like to put a rough Sharpie line where i intend to make the cut, then use a scribing tool to put an extremely thin line precisely on the mark. On smaller material where I can scribe with the sharp end of cheap calipers, I can easily hold 1/64" tolerance. On longer pieces with a tape measure, 1/32" is pretty practical. For most FRC purposes you would be using this tubing for, that is more than adequate, as the slop in your assembly will dominate the error equation.
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 18-12-2014, 10:30
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We used the 2x1 frame for our WCD chassis last year (basically a versachassis similar to what they have on the website).Worked great, no complaints. If the game has a flat field and no climbing, we will likely run the same thing again.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 18-12-2014, 11:15
Chris is me's Avatar
AKA: Pinecone
The .04" wall 1x1 is too thin for all but the most well supported, protected areas. If you cover the stuff in gusset plate or use it exclusively inside your frame where nothing can hit it, it's great. The .1" wall 1x1 should work well in most applications. We had good experiences using the 2x1 framing and all of the Vex line of gussets.
Depending on the application, you may want to drill out from 5/32nd rivets to the more standard 3/16th rivets. I really don't know who prefers the more oddball size.
Unread 18-12-2014, 11:37
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Please do NOT read what I am about to say as a knock against VersaFrame, it is a fantastic product!
If, and this is the qualifier, you have the ability to drill a 1" hole pattern accurately and repeatably, you can buy the raw materials and make most of the frame pieces your self. This will save you some $$, but not much time.
Now, when it comes to the gussets, I doubt you will be able to make the parts as easily, and accurately, and still save $$ and time. These gussets and mounts are a very quick and easy way to assembly your frames and structures.
All that said, isn't the whole idea behind VersaFrame and Gussets that you do not need the ability to machine accurately to use them? If so, then I guess my comments are a bit unnecessary. So, just take them as food for thought.
Unread 18-12-2014, 15:06
Andrew Lawrence
Posts: n/a
I designed 256's entire 2014 robot utilizing the 2x1x.1 tubing and the 1x1x.04 tubing, and it was by far the most competitive robot we've built to date because we were able to finish faster than we normally did even with the late shipping accident from last year, and our robot was strong and reliable. Like Chris said, the .04" thick 1x1 is not suitable for any application that takes a lot of load. Luckily 256's design last year did not use any 1x1 under load (apart from bumper support, but they took that fine) and it all held up for us. The new .1" thick 1x1 should solve that. Also agreeing with Chris, I prefer drilling out to 3/16 and using 3/16 rivets. 5/32 rivets are great if you're using 10 of them per joint, but with the linear fashion of the gussets we had some 5/32 rivets shear on our shooter last year, so drilling to 3/16 is helpful (and pretty easy).
In regards to the gussets, for almost every application the .09" thick gusset is great, except in some very specific high load applications we had our gussets bend over like paper (<110 degree bend). This was the one piece that held on our shooter so understandably there'd be a lot of torque there, and the easy solution for us was to just double up on the amount of gussets.
Like Bill said - the 1" hole pattern is pretty easy to replicate yourself if you have the resources and don't mind thicker tubing, and a lot cheaper. I like the .1" and .04" thick walls that you cannot get elsewhere, and the pre-drilled holes definitely saves you time. Having been on two teams on opposite sides of the resources spectrum, I've experienced the versachassis from both points of view. On 256, the versachassis enabled us to quickly and easily get a competitive robot put together with hand drills and saws. As a junior mentor on 1323, a team with a lot of resources, I've found out that the team uses the versachassis as well because of the time saved from not having to use our machines on fancy hole patterns and because of the thinner walls.
Overall I really love the VersaChassis system designed by WCP and VEX. It is definitely not the end all be all solution for every team, but for those who can benefit from it*, it is a fantastic way to bring your team up to the next level or enable your already competitive team to do more and save time.
*Disclaimer: I would not recommend this system for teams low on monetary resources or experience. Those teams are better suited for the kitbot because of its cheaper price and the manual that comes with it. I think the teams that will benefit the most from the system are: 1) Newer teams who have their stuff together and have a bit more money to spend than rookie teams but maybe not the machining capabilities of veteran teams, 2) Veteran teams who want to save time in the build season and use their machining resources for more important things, and 3) Veteran teams who have been around for a while but still may not have a lot of resources but do have experience and want to easily bring their game up to powerhouse level.
Unread 18-12-2014, 15:40
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
As with all products, it's how you implement the product that matters.
We used 1"x1"x.04" for our frame in 2014, except for the two main rails running down the center of our chassis that was bearing the load of the catapult tubing. No issues, no bending, we could have parked a bus on it. The trick wasn't the tubing but how it was designed into the final product. We did utilize a single gusset plate for the entire chassis instead of using many Vex gussets which improved rigidity.
We also used 1"x2" Vex VersaFrame for our catapult arm assembly.
With this we used the Vex gussets and found that the aluminum rivets were loosening up. We switched from aluminum to steel rivets on the gussets where the most load was being applied and they stayed nice and tight for the rest of the season.
Here's a link to a picture of the .04" wall chassis we used this year.
http://www.chiefdelphi.com/forums/sh...=pwnage+swerve
Unread 18-12-2014, 15:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
FWIW, we usually get 27 feet of 1x1" thin wall tubing for $30-something ($40-something one year) when we buy it in bulk and pick it up from our supplier ourselves. Even small online orders are substantially less expensive than VersaFrame. To me, VersaFrame isn't economical if the team can handle appropriate drilling of holes themselves. I agree it is very quick when used with the VEX gussets - but at a price.
2x1" is a bit more worth it due to the ability to make a very quick, easy-to-connect-to, precise drive train in many cases - but again, plenty of teams are better of using their skills to cut into bulk 2x1" rather than the VersaFrame. Personally, my team may or may not have a welder this year, so we may use Versaframe due to the gussets.
Not that VersaFrame is a bad deal under certain circumstances (valuation of time during FRC is hard...). However I think it's worth it to point out the tradeoffs in this type of thread.
Unread 18-12-2014, 15:59
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
It is great stuff, but I'm not sure if the pre-drilled holes and centerline on the tubing is really worth the cost. I would reccomend you heavily use Vex's gussets and mounts, but just buy your own tubing from OnlineMetals, MetalsDepot, or some other local supplier. Having holes to quickly mount things to is nice, but some measuring and drilling on the part of your team is probably worth the extra cost.
Unread 18-12-2014, 16:34
AdamHeard's Avatar
Lead Mentor
If the goal is to save money... don't buy from online metals.
buy full 20' lengths from a local metal supplier that chargers by the pound.
That being said, versatubing makes a lot of sense for most teams. The average robot would only use a hundred dollars of it tops.
Unread 18-12-2014, 17:40
Billfred's Avatar
Billfred Billfred is offline
This is pretty much what we did (in shorter lengths out of logistical necessity). We called our homemade 1x1 Worseaframe--it saved us money, but not necessarily time.
We used a heck of a lot of VEXpro gussets last year, and they held up nicely. I'd do it again if the application was right!
Unread 20-12-2014, 14:41
VladimirM's Avatar
Robot Captain
FRC #5631
Hi everyone!
Thanks for all the replies,
I think our team will end up purchasing this product for our first build. Good to note that in the future we can save money by constructing something like the VersaFrame in house if we get the machinery to do so.
Thanks again,
Vladimir Milicevic
Unread 20-12-2014, 21:58
Monochron's Avatar
Engineering Mentor
Originally Posted by VladimirM View Post
Hi everyone!
Thanks again,
Vladimir Milicevic
Glad to see you are planning to use it, it can be really useful.
I could be totally wrong here, but I'm not sure that you will get much use out of waiting until you have machinery simply to match the hole pattern in square tubing though. I wouldn't save money by replicating the hole pattern, I would save money by going without it.
Maybe I am undervaluing the usefulness of that hole pattern, if so could someone enlighten me? I see it as something that can save you some measuring when trying to line things up, but can also cause you to waste time cutting the tubing so the holes line up perfectly, and can make mounting near a hole a serious pain as it ruins the strength of the metal at that point.
