Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
  #181   Spotlight this post!
Unread 17-12-2014, 18:26
magnets's Avatar
magnets magnets is offline
Re: VEXpro 2015 Product line launch
Every single FRC team in the last 10+ years has had at least two 1/4-28 nuts on their robot.
Arguably the most standard FRC fasteners next to a philips head #6-32.
1/4-28's? Where do we use these commonly in FRC? Bimba cylinders are available with this thread, but that's all I can think of for common parts...
  #182   Spotlight this post!
Unread 17-12-2014, 18:27
Volunteer, WPILib Contributor
no team (Waiting for 2021)
It's the nuts on the breaker.
Team 4488 - Mentor 2013-2016
  #183   Spotlight this post!
Unread 17-12-2014, 18:28
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Main breaker
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #184   Spotlight this post!
Unread 17-12-2014, 20:07
Chris is me's Avatar
AKA: Pinecone
Originally Posted by sanddrag View Post
I'll take my axles without a hole through them, and my R8-2RS bearings are 1/3 the cost of a "Thunderhex" bearing, and are an industry-standard size. ;-)
The thing about ThunderHex is that while you can buy ThunderHex stock to use with it, you can make any hex shaft a ThunderHex compatible shaft just by turning it down a little on a lathe. You're not locked in to using Vex's shaft.
I'm excited about being able to do stepped shafts in one operation, using round bearings of varying sizes everywhere. Instead of making 1/2 hex, 1/2 round, 7/16 hex combo shafts, you could do 1/2" hex on one side and ThunderHex through the middle to the other side.
The bearings do cost more, yeah, but I'd pay $16 more per robot to avoid having to make stepped shafts, custom 7/16" hex broached sprockets, etc.
  #185   Spotlight this post!
Unread 17-12-2014, 21:29
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Originally Posted by tim-tim View Post
Just a habit of working on aircraft. The robots are vibration machines, so any little advantage to screws backing-out I will take. We have quite a few fastener stores in the area, so access to fine thread fasteners is not an issue.
That being said, we haven't used a 1/4" fastener on the robot in quite sometime - maybe a COTS component that required. We have used #10 rivet nuts in 1/4" holes in the past in the KOP frames.
I have found that Nylock nuts and bolts do not vibrate loose in FRC applications and if there is a situation where a Nylock is not suitable then we use medium strength thread locker. Once I introduced thread locker to the team there have not been any instances were a fastener came loose.
Where to you find rivet nuts that go in a 1/4" hole all the ones I've ever found use the annoying 19/64" bit. Because it is a less than common size we keep it in the kit with the rivet nuts so it is there when we need it.
  #186   Spotlight this post!
Unread 17-12-2014, 21:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Whoops. I didn't know that electrical used those.
I stand corrected.
  #187   Spotlight this post!
Unread 17-12-2014, 23:46
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Taylor View Post
Cool. What about it gives it the added strength? Is it the cross-section geometry? The alloy? The black anodizing?
People have touted the alloy, but the cross-section geometry plays a huge role here as well. The shape of the churro is particularly poor at transmitting torsional loads.
  #188   Spotlight this post!
Unread 18-12-2014, 06:17
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Yes, we have to drill the holes up to 19/64 as well. What I was trying to say is that even though the KOP chassis encourages 1/4" hardware, we still don't use it.
On a side note, it is always nice to keep a drill index on hand for things like this; but we to keep a drill bit or two in the bag with the riv-nut tool.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #189   Spotlight this post!
Unread 18-12-2014, 10:16
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Originally Posted by Andrew Lawrence View Post
The Talon SRX and the Victor SP are mostly the same product - they were designed in tandem by CTR and VEX. The only difference is that the Talon SRX is CAN capable, whereas the Victor SP only uses PWM. As a result the Talon SRX is negligibly larger, and costs about $20 more. For those who do not use CAN in their electronics, the Victor SP is probably their best bet, saving them $20 per controller, and for those who do use CAN, the Talon SRX is a godsend compared to the Jaguar, and well worth the money.
EDIT: Michael Hill covers some aspects of the Talon SRX that I had missed earlier in his post right after mine.
Amen. The team's really excited to finally be able to get all we wanted out of CAN* with all those extra features on the Talon now.
*In an actually reliable way
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #190   Spotlight this post!
Unread 18-12-2014, 12:07
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
There's always the situation where a new team member uses the #10 nylock nut on the #8 machine screw. Kind of seems to work, if you don't pay attention to tightening it completely.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
  #191   Spotlight this post!
Unread 18-12-2014, 16:48
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Originally Posted by Monochron View Post
Anyone know if we need to do separate orders for the new motor controllers in order to have any other parts delivered on time?
I ask because Andy Mark's site recommends that you put SPs/SRX's in a different order than you would other materials.
Yes, this would be helpful for our sales team as they're processing orders. Thank you for asking.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
  #192   Spotlight this post!
Unread 18-12-2014, 17:24
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
One of our students did that back in 2006 with a bunch of the old IFI sheet metal wheels. That didn't work out so well until we figured it out. The sprockets all started falling off.
  #193   Spotlight this post!
Unread 18-12-2014, 17:59
Grant Cox's Avatar
Back for more.
Originally Posted by BrendanB View Post
Anyone from Vex able to comment on the weight savings of the new Colsons compared to the previous live axle hub assembly teams used last year more specifically on the 4 x 1 1/2 wheels?
Official weights for all of the new VEXpro Colson wheels have been updated on their product page. Thank you for your patience, and sorry for not having those up at the initial launch
  #194   Spotlight this post!
Unread 18-12-2014, 21:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I put in a mixed order. Hopefully it will be OK ???
  #195   Spotlight this post!
Unread 18-12-2014, 22:17
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Ah, sorry. I called earlier today and the representative recommended that I put everything in one order. I am perfectly willing to split them, but I think the order is already fully in.
