| Thread Tools |
Rating:
Display Modes |
#196
Re: VEXpro 2015 Product line launch
The output shafts and shifting dogs for the WCP DS gearbox seem to be dead links right now. Do you still plan to sell the output shafts and shifting dogs separately?
Also, can the shorter steel shaft that fits inside the gearbox output shaft be purchased separately too? |
#197
What wire gauge and twist count is used for the CAN wires on the Talon SRX?
#198
While beta testing, our team used 20 AWG green and yellow purchased on separate spools (e.g., McMaster 8054T14) and twisted pairs ourselves with a vise and drill, to about 20 twists per foot. So far no issues. We twisted to get good handling/routing, not to solve an EMI problem. |
#199
-Aren |
#200
If the recommended wire and wire that is used are different, I would like to know both. I am assuming that that VEX Pro / CTRE would use the wire what they recommend; but, I can understand why they may be different. |
#201
That answers my question. Thanks
#202
http://www.vexrobotics.com/217-3628.html And yes the shifter output shaft will still be available by itself. http://www.vexrobotics.com/217-3635.html -Aren |
#203
Were you reusing the Nylocks? They are a one time use item, though you can often get by with using them a couple of times.
#207
We've still got one more thing for 2015 - the Ball Shifter Shaft v2 is now available.
#208
Now, if you would just get 2 CIM ball shifters in stock...
#209
The 3 stage 2 CIM ballshifters are back in stock (217-2615) the 2 stage ones will be back in early next week, several factors out of my control have been delaying shifters in general, wrapping them up.
-Aren |
#210
Excellent. Thanks!
