Go to Post We don't have to reinvent the wheel every year. (We have AndyMark to do that for us.) - GaryVoshol [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 20-12-2014, 18:38
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: ThunderHex Bearing Explained
If you can't wait for ThunderHex, and really want to use round bore bearings with hex shaft, you can always use a trick I used to use on 100.
Vex Pro sells metric roller bearings (217-2741) that have an OD smaller than the standard R8 size, and a bore larger than the distance across a hex's flats. We machined inserts for the bearing bore with a 17mm press fit OD and a 1/2" hex ID. If you were to machine a 1.125" OD 26mm ID adapter and press the VP bearing into it, you could basically get a R8 hex bearing where your actual bearing has a round, nonbroached ID.
Even though we put them in applications were they saw a lot of abuse (worm gearboxes), I can't make any recommendations about them being stronger/weaker than existing hex bearings. Because the bearing's race is thinner, I suspect the -2741 bearing is weaker than a hex broached bearing and almost certainly weaker than ThunderHex. YMMV.
That said, it was a cool trick that ended up being pretty useful in some designs. And, if you have a lathe and hex broach, it's a lot cheaper than ThunderHex.
-Plutarch
Unread 20-12-2014, 20:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Neat idea!
Alternatively, you can make a rotary broach holder for the lathe and buy a 3/8" hex rotary broach from littlemachineshop forless than the cost of a 3/8" broach.
Unread 20-12-2014, 20:34
AdamHeard's Avatar
Lead Mentor
Originally Posted by asid61 View Post
Neat idea!
I would wager 99.9% of teams can't just casually make a rotary broach holder.
Unread 20-12-2014, 20:38
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
And if you can, why would you not just make the broach as well?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 20-12-2014, 20:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
For the sake of discussion, opportunity cost...a rotary broach holder is over 10x more expensive than a rotary broach. Doesn't make sense to invest that much effort for a $65 tool.
At the same time I don't see the value in making the holder, as it will be worse quality than a COTS one and not work as well, while requiring significant time investment.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-12-2014, 20:46
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Ditto and you can even get custom sized broaches for about the same price too!
R.C.
MadTown Robotics Team 1323
Unread 20-12-2014, 22:41
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
This is a slick new product Paul, I can see where this would save a ton of time manufacturing drive shafts. Looking forward to getting my hands on some to try it out!
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 21-12-2014, 02:36
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Maybe. I am turning one in a few days/ weeks, so I'll let you know how it goes (tolerance, runout, ease of use, etc.). I've seen a number of guides on making them online.
