Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 20-12-2014, 23:55
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: ball shifter vs wcp ds
Originally Posted by BenSterling View Post
I would recommend belts over chain. Direct drive the center wheel with a gearbox and 2 or 3 cim motors and connect the outer two wheels to the center wheel with belts. A wet coast drive is a great choice.
I would recommend using 2 sims and not 3. Using 3 sims would be a little overkill, and has the possibility of burning our electronics.
Good luck this season and have fun!
The thing to make sure of with belts is that you have a precise tensioning solution - like a versablock- in mind.
3 CIMs will not burn your electronics and in fact takes load off of each individual controller in a pushing match at a given speed. That said, make sure not to try and push things in high gear - you'll blow the main breaker.
Edit: Monochron beat me to it!
