Go to Post We are all just pawns in FIRST's quest for global domination. - Tom Bottiglieri [more]
Unread 21-12-2014, 12:31
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: VersaFrame by Vex Robotics
Originally Posted by JesseK View Post
The hole pattern would immediately save an hour or two of drilling tubes/plates while simultaneously guaranteeing precision alignment with the VEX gussets. This compounds later down the road - imprecise rivet holes (1)require the piece to be re-made or (2) are more likely to fail, causing heartache during a match in addition to having to re-make the mechanism.
An hour or two of drilling? Maybe if I was trying to replicate the hole pattern, but I just don't see that much time used in putting a couple mount holes in tube. The time you lose cutting the tube so that multiple holes line up with multiple other holes would mitigate a lot time saved drilling in my opinion.
I could see the benefit of guaranteeing alignment with gussets, but again, only if you cut to the proper length. It is definitely a time saver to line up with gussets, no doubt, but you lose the ability to just get a length, clamp it to another piece, and drill right through.
Originally Posted by Chris Is Me View Post
This really isn't the case at all. A hole less than 1/4" in diameter is going to have minimal impact on a beam's resistance to bending, especially since the hole is not on the face normal to the hole. There is no noticeable difference in strength, certainly not even close to "ruining" the part.
My bad, replace the word "metal" with "mount hole". We tore the metal in a couple places our first year by having to drill multiple holes close to each other on some sheet metal. The metal itself held up, but the bolt in the correct hole tore its way over to a nearby hole and came out. That is what I was referring to.
