| The feeling of true love is a keeper. |
| Thread Tools |
Rating:
Display Modes |
#16
Re: DART Linear Actuators for the CIM Motor
What's the repeatable accuracy of this actuator in inches?
#17
I would imagine it is the repeatable accuracy of the potentiometer, which depending on the type/implementation, will be a number significantly less than 1.
#18
I think a more appropriate question is how much end play is there in each direction under load. I.E., how much backlash does the geartrain have. Of course, if you always put it in compression is isn't that much of an issue.
#19
Lash in the potentiometer gear mesh will also be a factor in repeatability, with the ones mentioned in the preceding posts. Of course, lash/play in the mechanism powered by this actuator will be (at least) equally important.
Can someone involved in making the demonstration arm shown in the linked video please measure and post the unpowered vertical play at the end of the arm? I think tape measure accuracy would be enough to give us all a good idea of what to expect. |
#20
A fully laden 12" Stroke Length, that's including the pot, CIM and limit switches it's 5.8. According to AndyMark the CIM is 2.8lbs so that would put the DART at 3lbs.
#21
We will set up a test to measure the unpowered vertical play in that or similar assembly in the coming week. |
#22
Dan,
Cool product and it looks great. I do have a question: what is the actual pitch, or lead, of the linear actuator itself? You gave us the gear ratio (that can be changed ... cool) but having the pitch is a crucial piece of information that many users may not realize they need. mm/rev, in/rev, mm/deg, mm/rev or whatever units suit your fancy would be appreciated. Thanks, Paul |
#23
Yow!, why so much?... well, let me know if the price comes down... otherwise I think for me personally it will be more benefit to make them from other cheaper parts. I know I can find good deals on lead screws for around 12-15 dollars.
#24
It appears that you're using a normal 3/8" ball bearing to take all the thrust loads from the lead screw. How does this bearing hold up to large impacts and high loading? I only ask because our team has seen issues with bearings falling apart due to high thrust loads.
#26
That said, with significant constant load increases there will be decreased bearing life and at some point they may need to be replaced. Since we were focused primarily on the CIM at higher speeds and forces less than 250 lbs I'd like to do some work here to determine what kind of load/life combos we could see. |
#28
There is another thread of similar nature that you may wish to check out here: http://www.chiefdelphi.com/forums/sh...93#post1397193 |
#29
Any news on when these will be available on AndyMark?
#30
The pages are up now and being populated with the technical bits. The DARTs should be available late this week/early next week at AM. The quickest way to get updates will be to select "Email Me When Available".
http://www.andymark.com/SearchResults.asp?Search=dart Thanks, Dan R. |
