Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Unread 21-12-2014, 22:38
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Good Screw Sizes fo General Use
5/32" rivets; #8-32, #10-32, and 1/4-20 screws.
The 5/32" rivets are most common individual hardware, followed by #8-32 and #10-32 screws for general purpose mechanisms. 1/4-20 screws are pretty much exclusively used for tube axles (dead axle shaft+standoff combo) or high-loading parts.
I try to avoid #10-24 and #6-32 like the plague as these are the most commonly broken tap sizes due to their ratio of pitch to shank diameter (look at a #6-32 tap wrong and it breaks), and #10-32 is WAY more common for COTS stuff.
Art Dutra IV
世上无难事,只怕有心人.
Unread 21-12-2014, 22:51
Oblarg Oblarg is online now
AKA: Eli Barnett
We use #10-32 and 1/4''-20 bolts (socket head preferable, hex head for 1/4''-20 also OK, phillips head is a no-no since they're basically designed to strip) for structural bolts. Trying to move more towards the former as the latter really is overkill for most stuff in FRC. Nylock nuts are standard.
After years of frustration, mismatched nuts, and accidental crossthreading, we will no longer purchase #10-24 on either team I mentor.
"The breakfast of champions!"
Unread 21-12-2014, 23:01
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Make sure you get the nylon/teflon nuts that self-lock (Nylock Nuts) so that you don;t have to loctite screws. They come in thick and thin profiles for different applications as well. They are so easy to use and never have I seen one vibrate loose if properly tightened.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 22-12-2014, 00:35
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We use mostly 10-32 on our robot. 1/4"-20 is good for some high-load applications. Dead axle screws.
Nylock nuts are really nice, but get some thin ones too. They come in heights of 9/32" normally and 1/8" (4/32") for the thin ones IIRC for 10-32 screws.
We use a lot of 1/8" rivets. Vex uses 5/32" for the versachassis. 3/16" rivets are interchangeable with 10-32 screws in terms of hole size.
Unread 22-12-2014, 03:17
Chris is me's Avatar
AKA: Pinecone
We use almost exclusively #10-32 hardware and 3/16 rivets so we only have to drill one hole everywhere. #8-32 screws and 5/32nd rivets are used to interface with weird Vex stuff sometimes.
Socket head cap screws basically every time.
Unread 22-12-2014, 05:59
Michael Hill's Avatar
Whatever the job requires. #10-24 is generally the first bolt we reach for (if something can't be riveted). We'll use 10-32 if we need more thread engagement, but they just take to long to screw in and out. Our one general rule is absolutely no metric unless we're forced to.
Unread 22-12-2014, 13:43
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The rule of thumb for thread engagement is in hard materials like steel you want 1x the bolt diameter and for soft materials like aluminum you want 2x the bolt diameter. That does not change whether you are using coarse or fine threads. If you look at standard steel nuts you'll find that their height is 1x the bolt diameter. So going to 10-32 to get more thread engagement isn't really gaining you anything in fact if it is in Aluminum you are more likely to strip the threads out of the item that you have tapped.
The only real advantages that find thread have are the the bolt itself is slightly stronger and that it is slightly less prone to loosening from vibration.
http://www.bestbolt.com/white_papers/white_paper_08.pdf
Unread 22-12-2014, 13:56
We're usually not tapping into aluminum when 10-32 were used. One way we used the 10-32 last year was in our chain tensioning system. We fed the 10-32 bolt into a helicoil. If we're tapping into aluminum, it usually is UNC. By far, 10-24 is the most common bolt we use. A recent exception was in an experimental drivetrain, because the only #10 SHCS we had was #10-32, and we needed that size and head type.
Unread 22-12-2014, 14:32
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
#8-32 screws are nice because you can easily cut them to size if needed.
We stock 1/4", #10, #8, #6, and #4. Socket cap is the only way to go.
I would also request some #10-32 rivet nuts (ribbed) and some #8-32 threaded inserts like this. The inserts are useful for bumper building.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 22-12-2014, 16:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We've standardized to 10-32 as much as possible. Generally SHCS style. Rivnuts, t-nuts, and nylok nuts. It has made life suck a whole lot less to standardize everything.
Unread 23-12-2014, 20:31
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Last year, almost everything we had was 10-32, allen-drive cap screws and nylon nuts (all steel). This worked out quite well for us; we might change to a different size or two this year (I'm mentoring programming this year, so not on top of the discussion), but we'll definitely have a small set of sizes for anything that we're building. When you do pick a standard size or sizes, STOCK UP ON TOOLS IN THOSE SIZE(S)! You'll never seem to have enough, since (for 10-32) everyone wants the 5/32" Allen and the 5/16" hex wrench at the same time.
Unread 23-12-2014, 20:39
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
What's the advantage of using socket head over button head?
2016: FRC 865 Mentor
Unread 23-12-2014, 21:12
Jared's Avatar
Jared Jared is offline
Socket head typically has a deeper hex, so it's harder to strip out.
I like 10-32's over 10-24's because it's harder to break the 10-32 tap. As a rule of thumb, I try to get more than 6 threads of engagement in a tapped hole in aluminum. With a 10-32, that works out to 6/32 = 0.1875", but a 10-24 requires 6/24 = 0.250".
Once you've used both for a while, it becomes easy to identify the different threads on bolts, and you can check to see if your nut threads easily on a known bolt.
We've used 1/4-20's as axles for flywheel shooters and pivots for catapult shooters, as well as gearbox mounts.
3/8-16 or 3/8-24 is our favorite for dead axles.
Unread 23-12-2014, 21:49
You must not have "determined" kids that will get that 10-24 nut on the 10-32 bolt. Yeah sure, it'll go on...with enough torque.
Unread 23-12-2014, 22:14
AKA: Eli Barnett
Quoting for truth. As mentioned earlier in the thread, our solution to this problem is to just not buy 10-24 anymore, which removes the potential for the error in the first place. On a team as large as 449, it's just not worth the hassle for the few places where it's nice to have coarser thread.
