Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 21-12-2014, 21:50
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Proto Type Base Built
Unread 21-12-2014, 21:53
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Re: pic: Proto Type Base Built
What size square tubing is that and what did you use to bend it?
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 22-12-2014, 00:37
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Why wide over long?
Looks pretty neat.
Unread 22-12-2014, 10:41
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
How are you planning on mounting gearboxes, wheels, etc?
Team 1002 - Website - Facebook - Twitter - Youtube
Unread 22-12-2014, 23:26
joeweber's Avatar
Coach team 1322
The tubing is 3/4 x 3/4. We bend it using a 3/4 EMT pipe bender used for bending electrical conduit. For mounting the wheels we will build pillow blocks that will allow us to adjust tension on the chains. The drive system is the same that we used last year, super shifters modified into a modular system that can be remove with just four bolts. More pictures can be viewed on our web site: http://www.team1322.org/ideas.htm#ANTI T-BONE FRAME
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 24-12-2014, 22:26
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
What was your reasoning behind the design of the interior frame pieces? It seems at first glance like two rails of C-channel, one on each side, perpendicular to the front and back rails, would have done a better job of holding the transmissions and bearing blocks, rather than the bent tubing shown. It also might be less complicated to build.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 25-12-2014, 09:32
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Very neat frame. One item I would caution about bending square tubing, You inherently weaken the column loading it can handle. Assuming the flat sides are the front and back, you will want 1 or 2 pieces to run for-aft on a chassis like this that are nice straight columns. Otherwise, with hard impacts, I would expect this frame to continue to bend and compress in length.
Unread 25-12-2014, 09:41
joeweber's Avatar
Coach team 1322
This frame is designed around our drive system which you can view on the link. When the drive is mounted it will add front to back support.
Unread 25-12-2014, 19:02
Which part of the drive do you use to strengthen the frame from front to back? Do you use the transmissions as stress members?
What I was talking about in my last post would look something like this:
\|__|/
(with the dotted front rail being at the front of the robot, I don't have a character that is a high horizontal line)
Unread 25-12-2014, 20:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Here's the image from the team 1322 site:
Built that in two hours? Wish we could get our build team anywhere close to that speed.
Unread 26-12-2014, 10:47
joeweber's Avatar
Coach team 1322
As shown above we use a special built bracket that we made for the super shifters to help strengthen the frame. We removed the 5 x 5 square tubing from the gear boxes and replaced it with the bracket which allows us to move the frame up a few inches in the bumper zone.
http://www.team1322.org/20140612_201621.jpg
Unread 26-12-2014, 10:59
Oblarg Oblarg is offline
AKA: Eli Barnett
Extremely non-conventional, but very cool, especially given the construction time. Maybe provide a video of it driving eventually?
"The breakfast of champions!"
Unread 26-12-2014, 11:09
philso philso is offline
FRC #2587
What happens to your frame when you apply a compressive force on two diagonally opposite corners? It seems that it is the two U-shaped pieces of square tube that keep your chassis from "parallelogramming".
Is there a reason you chose to use two u-shaped pieces of bent tubing vs. a single straight piece down each side? It seems that the manufacturing tolerances (bending cutting drilling) would have to be pretty tight to keep the six axles parallel to each other. How are the axles for the front and back wheels attached to the two left/right frame members? The holes for these four axles are not perpendicular to those frame members.
Unread 26-12-2014, 14:54
joeweber's Avatar
Coach team 1322
Depending on the game we will have sheets mounted to the frame to mount electrical and other items, this will give directional strength. If we use #35 chain we can just mount pillow blocks to the frame at the correct chain tension and that will take care of the axel mounts. I want to keep it simple for the students to build.
Unread 26-12-2014, 22:58
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The bracket mounting the gearboxes looks like a flat bar. Does it have any extension in the vertical direction? If not, you may have some flex in this member in a head-on or rear-end collision. This could momentarily reduce the chain tension. Combined with the sudden change in the traction force this could lead to losing the chain from the sprockets. I would actually consider that bracket (or some supplementals) to be part of the chassis rather than just a gearbox/wheel mount since it provides the continuous front-rear loading.
Also, why the 1-3-1 wheel count per axle? Does it help traction that much, or do you figure that it'll reduce the fraction drive force that must be delivered by chain (vice direct drive)?
I'm also in agreement with philso as to feeling queasy about not keeping the wheels aligned in a diagonal collision, or more properly with not keeping the sprockets in the same plane and losing the chain. We have never depended on a control board for this; at least since our second year we either used triangular structure or large (8") flat braces on everything but our wooden prototypes. I wasn't in the mix our rookie year (Rebound Rumble), but the control board was vertical, so it wasn't providing stiffness. On the other hand, I don't recall many robot-to-robot collisions in RR, so we may have just skated on that one.
Thinking about the things that can go wrong with this design makes me like the simple pseudo-WCD* design we're using for our prototyping tank chassis - short of bending the main c-channel members, there's no way a bumper collision can mess up the sprocket alignment or spacing.
* Pseudo-WCD in that we're using cantilevered axles, but not direct driving the center shaft. We're also using wheel bearings on fixed-mounted axles so imperfect machining won't cause (as much) wobble. Along the same line, we're using COTS shifters: AndyMark Super Shifters, but the design is adaptable to Sonic Shifters with just two more holes in the chassis and longer chains.
