Go to Post All labor is donated by the webmaster "Brandon". - Mike Martus [more]
Unread 22-12-2014, 00:05
Monitrech Monitrech is offline
FRC #2169 (KING TeC)
Monitrech can only hope to improve
Tips for Accurate Measuring and Machining
We do most of our machining by hand using only tape measures and calipers for measurements and sometimes have a difficult time properly marking and cutting or drilling accurately. I was wondering if anybody had any recommendations for tricks and best practices to get more accurate cuts (and hole placement in particular).
Unread 22-12-2014, 00:15
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Re: Tips for Accurate Measuring and Machining
If you use cad, you can print out 1:1 drawings and glue the to the part. might not look the prettiest afterwards, but it works.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 22-12-2014, 00:31
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Just use a small amount of rubber cement to attach the paper to the part and then you can remove it and rub the residue off.
Unread 22-12-2014, 00:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
What resources do you have? That will factor a lot in what you are doing.
To get really accurate placement of holes and edges, you should buy a height gauge on ebay. Only around $40 for a 12" tall one. Then buy a large steel plate or even better a granite surface plate. Use the two in conjunction to mark out lines and coordinates accurate to 0.001".
Invest in an angle plate, 1-2-3 blocks, or even just a good square to orient parts correctly.
We use a 36" ruler graduated in increments of .01" to mark out locations for long parts like WCD side rails. A loupe/ magnifying glass makes the small graduations easier to read.
If you can't afford the above, just get a 12" ruler graduated in increments of 0.01". Use that and a scribe to mark out coordinates for holes.
If you need holes to line up on 2x1, mmark one side and drill through with a small drill. Then drill both sides, one at a time or together, with the larger drill.
Use a punch to get hole locations accurate after you have coordinates marked out.
Unread 22-12-2014, 00:58
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Like Anand said, you can get pretty good precision with hand measuring tools. A surprising number of parts/features on our robots (brackets, angled cuts, etc.) are made this way.
My favorite set of low-tech tools for laying out holes and lines consists of a combination square, a blue marker, a scribe, and a center punch. When marking a hole, for instance, you can set the combination square to the X and Y distances to the hole from the edges of the workpiece, and scribe two lines to establish the point (use the blue marker to provide some contrast before scribing). Then mark the hole with a center punch, and drill with a center drill before the actual size you want, as twist drills tend to walk.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 22-12-2014, 02:12
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
Give this man a cookie! This method WORKS!!! And is very easy to do, and calipers can also be used to scribe in lines.
Unread 22-12-2014, 02:22
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
While a fast method, it's not very good practice unless you have scribing calipers which have carbide tips. If you are going to do it, use a cheap pair, make sure your students know not to scribe with the $100 pair, and only on soft materials.
3476 has some great layout tutorials using a pair of calipers and a scribe on their website.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 22-12-2014, 12:13
IronBenderII IronBenderII is offline
FRC #3859
IronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond repute
We have struggled with the same thing so this year we invested in Incra Rules/scribes/Dykem Blue this year and so far it's helped a ton.
http://smile.amazon.com/s/ref=nb_sb_...le%2Caps%2C325
http://smile.amazon.com/gp/product/B...?ie=UTF8&psc=1
Hope this helps!
Jack Covert
Team 3859
wolfpackrobotics.org
Unread 22-12-2014, 12:39
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
These are great for marking holes
http://www.atgstores.com/chisels-pun...g&gclsrc=aw.ds
Unread 22-12-2014, 12:47
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
I would avoid using calipers as a scribe. Inexperienced eyes are watching & may not not understand when not to do it.
Beware of the thickness line that the tool you use to mark. You can make a V with the apex of the V being center of the mark. Be aware of the offset of the scribe to the straight edge.
Unread 22-12-2014, 13:59
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
One tip I picked up from working at a machine shop is make a quick vice end stop if you are making many identical holes or features on parts. You can make them or buy them for most vice types, and they can make your life much easier.
This device is also amazing if you decide to take the part off to test it and must re-install it on the vice for further machining (for prototyping and the like).
Another must-have tool for machinists is an edge finder. They are very cheap and can be quite accurate and precise. As long as you have a smooth surface to use it on you can get very tight zero locations on your CNC machines. I used a regular $15 edge finder at a reference standard company that required location tolerances of 0.0001-0.00005" and with some practice the edge finder was able to get those tolerances (not that you will need anything near that in FRC).
Unread 22-12-2014, 14:08
Charles Boehm's Avatar
Charles Boehm Charles Boehm is offline
Build Team Lead, Weapons Officer
AKA: Charles
Charles Boehm is a jewel in the roughCharles Boehm is a jewel in the roughCharles Boehm is a jewel in the rough
Our team uses this for most everything we cut that isnt on the vertical mill or the lathe.
Achievements since I joined
2016 Minnesota North Star Regional - Winners (Thanks 3130 and 3042) -Industrial Safety Award - Gracious Proffesionalism Award
2014 Minnesota State Champions - Rank #1 (Thanks 2052 and 4778)
2014 Archimedes Division - Quarter finalists (Thanks to 399 and 2056)
2014 North Star Semifinalists (Thanks 967 and 4607) - Creativity Award - Safety Award
2014 Northern Lights Winners (Thanks 359 and 2502) - Excellence in Engineering - Safety Award
2013 Minne-Mini Winners (Thanks 2169, 3883, and 4239)
2013 MRI Winners (Thanks 2052, 3130, and 3313)
2013 MN State Fair Winners
2013 IRI Participant
2013 Minnesota State Championship - Winners (Thanks 2052 and 4607)
2013 Galileo Division - Finalists (Thanks 2169 and 3284)
2013 North Star Regional - Winners (Thanks 967 and 4607) - Team Spirit Award
2013 Northern Lights Regional - Quarterfinalists (Thanks 3130 and 1675!) - Entrepreneurship Award
Unread 22-12-2014, 14:52
I found this pdf explaining how to use caliper tips as scribes for accurate measuring, although it doesn't look too good for the calipers.
http://www.botlanta.org/uploads/pdf/caliper_abuse.pdf
Unread 22-12-2014, 16:52
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Buy some cheap calipers that are used for light scribing and hand made parts. Keep the expensive calipers/micrometers with the machines where they are used specifically for measuring part tolerances. Also, most of us are using 6061 aluminum, it will take a while to damage the tip of a steel caliper as long as you aren't trying to cut your part using the ends. When you use marker to pre-mark the surface before etching you barely even have to touch the surface to make your line.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 22-12-2014, 17:38
AmiableVariable's Avatar
AmiableVariable AmiableVariable is offline
the ginger one
AKA: Hannah Fritsch
FRC #4488 (Shockwave)
AmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to all
As mentioned above, for a lot of layout, a good square, a sharp pencil, fine tip sharpie or scribe and layout die, and ruler are your best friends. Height gages are also incredibly helpful, though do make sure that the surface being marked is perpendicular to the surface the height gauge is resting on. Tape measures are usually better for longer pieces. Also, thinner layout lines and marks allow for higher precision.
First off, make sure everyone manufacturing parts remembers to consistently zero calipers and measure from zero on the rulers, not the end.
Regardless of which tools you get: Pick your battles, and be sure you have the best (least variation) possible reference points.
For example, it's less precise to use a rough cut edge (cut with bandsaw or hacksaw) as a reference point to mark out holes, because it gives an uneven starting point. It would be better to mark a straight line that is perpendicular to a trustworthy side (or a set of perpendicular lines, if everything is rough cut) and measure the distances from that. If this is done before the final cut of the shape, you could later use those reference lines to cut the final edges.
When drilling holes to mount parts like a versa-planetary, mark the center for where the shaft is going to go first, because that is typically going to be the most important part relative to the rest of the design. Then, mark up the centers for the rest of the mounting holes relative to the critical center-point, not from the edges of the part. Unless it's a very compact design, having a slight rotation in the motor mount should cause a less trouble than an incorrect distance between mounting holes. If the rotational alignment is important, pick the two most important points on the piece (or the two that are the furthest apart) and measure those first.
When actually drilling hole, center punches and pilot drills help. In regards to cutting pieces, the thinner a line you can give machinists to follow, the better. Additionally, mark which side of the line you would rather have them err on. If you need a smoother line right at the mark, cutting a little large and filing the part down to the line is always an option.
Hope this helps!
