Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 21-12-2014, 19:35
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: DART Linear Actuators for the CIM Motor
What's the repeatable accuracy of this actuator in inches?
Unread 21-12-2014, 21:13
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
I would imagine it is the repeatable accuracy of the potentiometer, which depending on the type/implementation, will be a number significantly less than 1.
Unread 21-12-2014, 22:04
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I think a more appropriate question is how much end play is there in each direction under load. I.E., how much backlash does the geartrain have. Of course, if you always put it in compression is isn't that much of an issue.
Unread 22-12-2014, 05:58
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Lash in the potentiometer gear mesh will also be a factor in repeatability, with the ones mentioned in the preceding posts. Of course, lash/play in the mechanism powered by this actuator will be (at least) equally important.
Can someone involved in making the demonstration arm shown in the linked video please measure and post the unpowered vertical play at the end of the arm? I think tape measure accuracy would be enough to give us all a good idea of what to expect.
Richard Wallace
since 2003
Unread 22-12-2014, 09:53
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Originally Posted by cbale2000 View Post
How much does it weigh without the CIM motor?
A fully laden 12" Stroke Length, that's including the pot, CIM and limit switches it's 5.8. According to AndyMark the CIM is 2.8lbs so that would put the DART at 3lbs.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 22-12-2014, 10:03
iR3 Creative
AKA: Dan Richardson
You are correct, there will be the backlash in the POT gears, pulleys and screw. You also need to take into account the bit rate of the controller as well if being driven by position commands via feedback from the pot.
We will set up a test to measure the unpowered vertical play in that or similar assembly in the coming week.
Unread 22-12-2014, 10:46
President, VEX Robotics, Inc.
Dan,
Cool product and it looks great.
I do have a question: what is the actual pitch, or lead, of the linear actuator itself?
You gave us the gear ratio (that can be changed ... cool) but having the pitch is a crucial piece of information that many users may not realize they need.
mm/rev, in/rev, mm/deg, mm/rev or whatever units suit your fancy would be appreciated.
Thanks,
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 22-12-2014, 12:45
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Originally Posted by Dan Richardson View Post
The DART Linear Actuators will be introduced at around $380.
Yow!, why so much?... well, let me know if the price comes down... otherwise I think for me personally it will be more benefit to make them from other cheaper parts. I know I can find good deals on lead screws for around 12-15 dollars.
Unread 22-12-2014, 13:12
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I'm thinking it is priced there because it is a good combination of power and speed. The two other similar products linked here and here are both a fraction of the speed that the DART is offering. I'm also guessing that the DART is going to be easier (legal?) to modify, thus giving you much better control of efficiency.
Unread 22-12-2014, 15:09
magnets's Avatar
magnets magnets is offline
It appears that you're using a normal 3/8" ball bearing to take all the thrust loads from the lead screw. How does this bearing hold up to large impacts and high loading? I only ask because our team has seen issues with bearings falling apart due to high thrust loads.
Unread 22-12-2014, 17:18
Tom Line's Avatar
As for modifying, consider that any motor or transmission with a cim shaft output can drive this. If these turn out to be robust (per the question about how the thrust load is handled) then it's pretty neat what you can do with it with COT's components. Utilizing versa planetaries will result in just about any speed you can imagine.
Unread 23-12-2014, 00:49
iR3 Creative
AKA: Dan Richardson
Originally Posted by Paul Copioli View Post
Dan,
Thanks,
Paul
Thanks for the kind words Paul. The lead screw has a .500" O.D. and a .200" Lead. This information hadn't made it's way to the website but we've since added it and a calculator to help you determine Forces and Speeds for a custom configuration.
We're dedicated to producing affordable components for all FRC teams and we will continue to look for ways to improve our design and manufacturing processes to help bring the cost down. As Monochron pointed out, this ground up solution will bring a competitive advantage over other comparable linear actuators. Our actuator is also less expensive than many of the other industry alternatives that allow for similar power density.
We iterated on the design and selection of bearings in the design process and landed on a high load capacity ball bearing that has performed well in testing. We have safely operated the linear at greater than 300lbs with no damage.
That said, with significant constant load increases there will be decreased bearing life and at some point they may need to be replaced. Since we were focused primarily on the CIM at higher speeds and forces less than 250 lbs I'd like to do some work here to determine what kind of load/life combos we could see.
Unread 28-12-2014, 21:41
JamesTerm's Avatar
Terminator
AKA: James Killian
I guess everyone has different needs ours is affordability probably under 100 dollars and it doesn't need all the bells and whistles offered on the high end product. I'm not sure if there are others that would like to save money, but if there are... perhaps there is a dialed down version... that might not offer as much force, but could be made with cheaper parts for a cheaper price. I plan on having some solution in the near future on a side project I'm working on.
There is another thread of similar nature that you may wish to check out here: http://www.chiefdelphi.com/forums/sh...93#post1397193
Unread 05-01-2015, 10:50
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Any news on when these will be available on AndyMark?
Unread 05-01-2015, 18:34
iR3 Creative
AKA: Dan Richardson
The pages are up now and being populated with the technical bits. The DARTs should be available late this week/early next week at AM. The quickest way to get updates will be to select "Email Me When Available".
http://www.andymark.com/SearchResults.asp?Search=dart
Thanks,
Dan R.
