Go to Post Engineering rules of thumb don't form the garbage that goes into the making of the robot. They take the garbage of the real world and turn it into more pure, if slightly diluted, data. - DampRobot [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 21-12-2014, 14:46
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: pic: Bit Buckets 2015 Offseason Drivetrain
Originally Posted by z_beeblebrox View Post
I re-uploaded the model; try downloading again.
Is it just me or did the Download All button go missing. I now have to download all of the files individually.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #32   Spotlight this post!
Unread 21-12-2014, 14:51
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Missing for me too. That's odd.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
  #33   Spotlight this post!
Unread 21-12-2014, 14:52
AKA: Roger Moore
Could it be a setting in the project?
Stronghold
Student 2013-2016
  #34   Spotlight this post!
Unread 21-12-2014, 14:54
Custom User Title
AKA: Cal
I don't see anything.
  #35   Spotlight this post!
Unread 21-12-2014, 17:21
AKA: Roger Moore
The Button is Back!
Stronghold
Student 2013-2016
  #36   Spotlight this post!
Unread 22-12-2014, 03:11
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Very nice. Our team has had laser cut chassis for the past two years, but they are nowhere near as modular as yours.
  #37   Spotlight this post!
Unread 22-12-2014, 18:13
Custom User Title
AKA: Cal
Thank you. We looked at your team's robots when we were trying to figure out whether or how a laser-cut robot would work.
Do you guys have any experience with wood gearboxes or bearing press fits? We're trying them on this robot but won't have much time to test them before build season.
  #38   Spotlight this post!
Unread 23-12-2014, 02:32
FRC #1899
We've never done wood gearboxes, but bearing press fits work fine, you just have to make the hole a hair smaller than the size of the bearing.
Is your chassis held together entirely with T-slots? We thought those would not be strong enough, so we use wood glue for everything. It probably helps that you are using 1/4" plywood, rather than 3/16".
  #39   Spotlight this post!
Unread 23-12-2014, 02:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
How small is "a hair smaller" for wood?
Press fits in metal are pretty precise. 0.001" smaller than the bearing is a light/ medium fit, whereas 0.002" is a heavy press fit, for the usual FRC bearings. Wood would be more forgiving on the size.
  #40   Spotlight this post!
Unread 23-12-2014, 10:03
Custom User Title
AKA: Cal
Everything is held together with t-slots.
We've experimentally found that cutting the bearing holes .006" undersize compensates for kerf and gives a pretty tight fit. I imagine that this number varies with laser model and material.
  #41   Spotlight this post!
Unread 23-12-2014, 13:00
FRC #1899
Like z_beeblebrox was saying, the number varies due to the laser kerf, as well as the softness of the wood. If you haven't tried it before, I would cut a test piece with different sized holes in 0.001" increments to determine the ideal size. The other option is cutting holes slightly too small and sanding the inside until the bearings press fit.
  #42   Spotlight this post!
Unread 23-12-2014, 14:42
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thank you, I will file that away for when we use wood.
  #43   Spotlight this post!
Unread 30-12-2014, 16:00
Custom User Title
AKA: Cal
Here's the next version of the drivetrain. It maintains the same general design as the last iteration, but the CAD model has been completely redone. It is now better organized and entirely equation driven- the length, width, height and other properties can all be adjusted by changing numbers in a text file.
This model is not intended to be cut out as-is. It's intended as a base that a team can quickly and easily adapt to any game, changing the size, wheels, gearbox or anything else. As such, the gearbox mounting, which is intended as an example, is not equation-driven and the model includes no lightening or access holes, wheels or axles.
The electronics layout is also not a final design - it is simply a demonstration of how SolidWorks' blocks can be used to quickly draw an electronics board.
The gearbox included in the model is a repackaged Vex Pro Ball Shifter. Its only custom parts are the 4 wooden enclosure pieces.
SolidWorks files are available on GrabCAD here. Look in the folder "2015 Offseason Drivetrain v2 Upload".
