Go to Post I thought we agreed to just put up a teaser, not a picture of the robot! - IBdrummer [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 22-12-2014, 17:28
Joining the 900 Meme Team
FRC #0079
Re: Best gyro for frc.
Originally Posted by seg9585 View Post
Correct -- I accumulated the last 50 samples, averaged the value (divide by 50), and calculated the new heading (this means the heading is updated at 20Hz, not every 20ms).
The reason I had to do this is because the most accurate Timer I could find in the Arduino was only accurate to the nearest 1ms and this introduced significant heading error when calculating time delta, particularly at high rates.
Happy to post my code if interested.
What do you mean the most accurate timer was 1ms? Unless you meant microsecond instead of the millisecond I'm assuming that means.
  #32   Spotlight this post!
Unread 22-12-2014, 17:34
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Hmm, I was using the millis() function and did not realize there was a micros() available. Reviewing the Arduino library I now see it is available, so I'll go back and modify my code to use it. This could help to increase heading sample rates.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
  #33   Spotlight this post!
Unread 22-12-2014, 17:40
FRC #0079
That's what I assumed, do note that micros() returns multiples of 4 (or 8 on 8mhz arduinos).
You might also want to look into using interrupt driven timers.
And while on the topic of timing and arduino, for timing dependent tasks write the code yourself. Tests I did a couple years back showed that there's a SIGNIFICANT overhead for the arduino digitalWrite compared to the comparable C code. I'd always assumed they were just macros but they actually include a fair bit of code.
  #34   Spotlight this post!
Unread 22-12-2014, 17:52
seg9585's Avatar
AKA: Eric
As in the long variable returned will always be a multiple of 4 (or 8), or a return of "1" actually means 4ms? If the former, no impact since I am just comparing time now to time at last sample collection.
I'm using SPI.transfer(data), not digitalWrite. Is there a more efficient method than this one?
My FIRST legacy:
  #35   Spotlight this post!
Unread 22-12-2014, 18:00
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Has anyone thought about making an aftermarket board that plugs straight into the expansion port on the rRIO that includes a gyro built in as well as pwm expansion and dI/O and analog expansion?
  #36   Spotlight this post!
Unread 22-12-2014, 18:08
seg9585's Avatar
AKA: Eric
Gyros are very sensitive to electromagnetic fields, this may be a problem so close to the roboRio.
Even if it wasn't, the chip I tried in particular is a single-axis gyro and will require more precise mounting on the robot. Many teams like to mount cRios/roboRios vertically or in a way convenient for troubleshooting or maintanence. Maybe an embedded 3-axis gyro would solve that problem, like the rRio's 3-axis accelerometer.
My FIRST legacy:
  #37   Spotlight this post!
Unread 22-12-2014, 22:38
seg9585's Avatar
AKA: Eric
I added a calibration task that samples 5 seconds of data at 1kHz and calculates the bias from this. And I used micros() instead of ms counts and removed the smoothing, so now the heading is updated at 1kHz as well.
Result: ~1 deg drift in 10 minutes. I think that'll be good enough.
Photo of the setup (3D printed protective case):
Serial Output:
My FIRST legacy:
  #38   Spotlight this post!
Unread 23-12-2014, 09:16
FRC #0079
Looks like you already figured it out, the returned value will always be a multiple of 4.
I'd be willing to bet doing the SPI write yourself would be more efficient but it's probably not a huge deal. The only reason I did any tests was I needed faster executing digital writes. It was mostly an example of how the wrapper library is pretty inefficient.
Mounting the gyro near the roboRio probably won't be an issue. Every time I've run a gyro has been an analog gyro, the issue was that the signal got messed up by the magnetic fields caused by currents driving motors. Minimizing transmission distance should help you there. But this gyro talks SPI so it's less susceptible to that issue.
  #39   Spotlight this post!
Unread 23-12-2014, 12:54
You can also throw a ground plane under the gyro to block most of the magnetic fields that might be there. That's good practice anyways.
  #40   Spotlight this post!
Unread 23-12-2014, 13:46
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Not to bust your chops, but that's true for electric fields -- not so much for magnetic fields. Effective magnetic shielding requires the use of a material with a high magnetic permeability such as Mu-metal (Carpenter Specialty Alloys). Rolled foil copper such as that found on PCBs has little effect.
  #41   Spotlight this post!
Unread 24-12-2014, 01:51
I wasn't quite sure that I hadn't mixed the two up when I wrote the post. Thanks for calling me out on it
  #42   Spotlight this post!
Unread 25-12-2014, 17:15
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Kauailabs will be announcing exactly what you describe on January 3.
  #43   Spotlight this post!
Unread 25-12-2014, 18:02
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Awesome, any plans to offer official Python support?
2016: FRC 865 Mentor
  #44   Spotlight this post!
Unread 25-12-2014, 18:09
AdamHeard's Avatar
Lead Mentor
What gyro specifically?
Thanks
  #45   Spotlight this post!
Unread 25-12-2014, 19:30
Software Mentor
AKA: Scott Libert
Thanks
Invensense MPU-9250 (9-axis sensor).
Plus an on-board 32-bit ARM microcontroller, providing motion processing and calibration algorithms for accelerometers, gyros and magnetometers. Minimal yaw drift due to filtering/fusion algorithms. UART, SPI, I2C and USB interfaces. Open source hardware and firmware. C++, Java and Labview libraries for the Roborio will be available, too.
