Go to Post If I thank everyone that I want to, we might be here for a while - Karthik [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 01-03-2003, 15:48
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
The Banner sensors just use current sourcing, so it should be safe just to hook the Brown and Blue wires up to the battery as you would normally, and put the white wire to the EduRobot digital input (+).
The manual says the sensors need 10-30V DC to operate normally, so you might need to use 2 9V batteries connected in series for this to work.
Basically:
1. Connect the (+) terminal of one 9V battery (Battery1) to the (-) of the other 9V battery (Battery2).
2. Connect the Blue wire to the unused (+) terminal on Battery2.
3. Connect the Brown wire to the unused (-) terminal on Battery1.
4. Connect the white (or black) wire to the (+) on the EduRobot digital input.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
EDUbot Sensors marlon_jbt Robotics Education and Curriculum 11 19-12-2002 13:38
