Go to Post When our arm "spontaneously combusted in the middle of the field", your team was the first to offer assistance to help fix it. - KTorak [more]
Unread 23-12-2014, 18:08
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Swerve Optimization
There are a lot more swerve threads this year than I remember in recent years and there is a lot of debate about the various designs. I would like to hear from the swerve veterans and the many designers: what are you trying to optimize with your design? I ask this as someone who loves design optimization, but knows very little about building a practical swerve module.
I see a lot of discussion around module weight and it appears under 8 pounds per module is “good”. Quickly comparing with a 6WD COTS WCD at Vex I get 22.01 pounds without fasteners (see below) compared with about 32 pounds for a swerve. This is actually quite amazing considering a swerve has 4 additional turning motors and their gearboxes!
I realize that swerve gives some pretty cool maneuvering capability for the ~10 extra pounds. And yes, I know that there is significant effort into learning to code and drive a swerve correctly on top of the added difficulty of custom machining 5+ modules during the build season.
As I said above – I want to know what the general focus is on with the many new swerve designs. What are you trying to optimize? Some ideas from the various posts (in no particular order):
  • Weight of module
  • Size of module
  • CG of module
  • Ability to rotate infinitely (i.e. not constrained by wires twisting)
  • Gear Reduction available
  • Two Speed modules
  • More?
I am also interested to know at what point could swerve become COTS (yes I know about the Revolution Pro)? What would the price need to be? What would the weight/size/etc have to be for the non-diehard teams to get them?
-matto-
6WD COTS WCD
  • 2X 2 CIM Ball Shifter (2.50 lb ea)
  • 4X CIM Motors (2.80 lb ea)
  • 6X Versa Blocks (0.22 lb ea)
  • 6X Colson Performa 4"x1.5" 1/2" Hex bore (0.53 lb ea)
  • 8X 9mm 18T pulley (0.03 lb ea)
  • 4X 9mm 160T belt (0.07 lb ea)
  • 1X 36” 1/2 Hex Stock (0.79 lb ea)
Unread 23-12-2014, 19:19
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Swerve Optimization
I'm no expert but my priorities were (in order):
1. Cost
2. Reliability
3. Low Machining Complexity
4. Low Weight
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 23-12-2014, 19:41
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
For last years it was.
1. Low machine time and complexity.
2. Efficiency (bearing over bushing ect getting the most per cim as possible)
3. Strength/rigidity
4. Cost
5. Weight
Also the foot print was played with. Most every thing was focused around how to make it as less complex as possible. One thing we did sacrifice was assembly... We did not think about that very much.
We also spend a lot of time in programming optimizing the steering algorithms along with some things to improve brown outs in the CAN bus.
Unread 23-12-2014, 20:07
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
For the (tank) drivetrain my team is working on, our top priorities are basically:
-Is easy and fast to fabricate, assemble and maintain
-Is robust and rigid
-Is easily adaptable to different configurations
-Allows for mounting of electronics and pneumatics
-Has low center of gravity
-Has low weight
-Is compact
If we were ever to make a swerve, the priorities would likely be similar.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 24-12-2014, 03:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
After actually attempting to create a swerve drive recently:
1. Machinability
2. Weight
3. Easy to assemble
4. Cost
I machine literally all the parts on our team, so I have a bias against hard-to-machine stuff now.
COTS swerve drives are prety much only available from 221, but that's fine. Their Revolution Swerve is very easy to incorporate into a decent swerve design.
To OP: For your 22lb estimate, you forgot to add the weight of the chassis itself. 0.1" thick tubing all around plus bellypan. Many of the recent swerve designs (particularly Aren's basic design) can be implemented without too much extra design work to make a whole chassis with 0.0625" thick tubing weigh around 34-35lbs. A 4-cim WCD might be a few pounds lighter for a very good one.
SWERVE 4 LYFE
