Go to Post What is the airspeed velocity of an unladen wiffle ball? - The Doctor [more]
Unread 22-12-2014, 17:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Swerve again, for fun
Originally Posted by Bryce2471 View Post
What makes you say that? Do you know the weight?
We can presume that Kevin from 2451 has a pretty good guess for how much it weighs when he says
It has to be the most compact and lightest swerve to date!
due to
Originally Posted by Aren_Hill View Post
Showed this to Kevin on 2451 and he took off running and now has a fancy 2 speed version.
Unread 22-12-2014, 17:43
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Just curious, is there any way we can get our hands on the CAD files to take a closer look at the module? I know this may be a stretch but worth a shot too: If a team wanted to build this, would the spec sheet include all the parts that come together to make this?
Unread 22-12-2014, 17:57
AdamHeard's Avatar
Lead Mentor
Originally Posted by asid61 View Post
+1. I have a swerve design exactly like this on my computer, except with a 2" colson instead of a 3.25" versawheel, ad it weighs a minimum of 5.3lbs. Still heavier than Bryce's swerve, albeit only very slightly.
Plus, making it into a shifting version requires a lot of weight unless you don't use a COTS shifter shaft.
EDIT: Of course, if anybody could make the design lighter it would be Aren. So it could be lighter actually.
Very nice swerve Aren. It's cool seeing your drives. Are you using a dead axle? Is it possible to flip the cim?
I don't think theoretical weights are fair to compare. If the system isn't made and working, it doesn't matter how light it is.
I could go design a 4 lb swerve now, no guarantee it will work or hold up. Many of the recent designs posted aren't robust enough to survive a season (I think Aren's here would though, as he's fielded 5+ swerves at this point I think).
Unread 22-12-2014, 18:08
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Couldn't have said it better.
Unread 22-12-2014, 19:51
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
I have to ask were some of the concepts for this taken from my teams designs i posted over the summer? Looks really clean and well thought out.
http://imgur.com/a/H6Qcm
Unread 22-12-2014, 22:50
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We're looking at a theoretical model right now, so it makes sense to compare theoretical weights. Kevin's theoretical weight for his shifting design posted a few months ago was ~7lbs IIRC, whereas Bryce's models for shifting designs weighed around 6.3lbs. Even if it wouldn't survive a season as in the CAD, there's at least 0.5lbs to play with to buff it up. And Kevin's design used only small steel miter gears, whereas this design uses much larger steel bevel gears.
Given that, I think it's possible that this weighs more than many designs posted previously. However, it is much more compact, and for many situations that can be more valued than the weight.
If you believed that none of the recent designs can survive the season, then you really should have said so ealier, when those designs were posted.
Also, I found this yesterday:
http://www.chiefdelphi.com/media/photos/34178
So Aren beat himself some years ago.
EDIT: How is the bevel gear constrained axially on the shaft? Does it depend on the wheel to position itself properly?
Unread 23-12-2014, 08:43
Gdeaver Gdeaver is offline
FRC #1640
This years game was hard on our swerve modules but they are still going strong. I would pick a robust module over a cute light weight module any day. So I say to those who have caded all those modules in the off season, Make them and beat them. Do they perform and survive? Then it is a good design. Until then it's just a concept. We made a CVT module this off season. Do we do it this year? I don't know. I'm leery of adding complexity to an already complex system. I guess it depends on the game. But, we made it and tested it. Made revisions and beat it. First has become brutal. Will 2015 continue this trend?
Unread 23-12-2014, 11:08
FRC #2451 (Pwnage)
The larger gear in Aren's design might be larger but the smaller gear is much smaller. I would go off tooth size and not OD of the largest gear.
Our actual module weighs in at 7.5 lbs with no additional lightening of the gears, etc. This is too be expected since all the steel screws weren't added to the CAD model. We'll post a video of it driving around just as soon as it is, should have it powered up this afternoon.
Unread 23-12-2014, 14:39
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The smaller gear is probably 15t or 18t compared to the 20/40 combo I use in my modules, but I don't know for sure. I tend to use 1 module gears (about 24 pitch) for my stuff.
The weight comes not only from the teeth but the face of the gear I think, as well as the hub. As the diameter of the gear increases the area/ volume of the gear increases considerably.
You actually made your module? Super cool! I'll be looking forward to seeing it driving.
Unread 23-12-2014, 15:23
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Great looking swerve Aren!
When you get it working Kevin, it would be awesome to see a video of it working!
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 23-12-2014, 17:48
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Not everything that 1625 has ever done was designed by Aren, many things were, but his senior year on our team was 2008. He helped out up till about 2011, he moved on to help 3928 and 148 after. He did a lot for our team, but their were (and are) a lot of talented people who deserve credit for 1625s success.
Example: I led the design on this module as well as the 2010 6 wheel swerve.
"More power 'till it breaks or you win."
- Keith Carey
Unread 23-12-2014, 19:51
Aren_Hill's Avatar
Build Nifty Things
^Dillon is the guy who did half the stuff I get credit for, cause Internet.
(And if I made that tiny module, the lightening pattern would've been way cooler looking )
A guy who likes robots.
Unread 24-12-2014, 03:16
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
OMG I'm so sorry. I didn't double check the author.
How did 6 wheel swerve work out?
Unread 24-12-2014, 03:22
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Went to Einstein allied with 2056 and 3138
also:
Finalists at GKC along with Engineering Excellence,
Semi-Finalists at Midwest along with Regional Chairman's
Galileo Division Champions
Never ranked lower than 3rd after quals at any regional or champs, overall season record of 36-13-1
sooooooo...
*Fun fact, only 6-Wheel Swerve to ever be on Einstein
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 24-12-2014, 14:24
Chris is me's Avatar
AKA: Pinecone
Aren never ceases to break my head with his designs. The non-coaxial power transfer is so cool. I like how you use the 16-style bearing thing to avoid using any shafting at all holding the module up. I like how your crazy ideas make complete sense in terms of the problems you're trying to solve.
It doesn't look like you have any sensor feedback on the wheel (velocity, you have a thing for angle i think). Do you have something planned for that? This seems like a cool application for that on-CIM encoder that's been going around CD these days.
He's not objecting to the designs, he's objecting to comparing the weight of untested CAD models. He had no reason to make this point until this happened, so I don't think it's a fair criticism.
