Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 23-12-2014, 21:49
Michael Hill's Avatar
Re: Good Screw Sizes fo General Use
Originally Posted by Jared View Post
Once you've used both for a while, it becomes easy to identify the different threads on bolts, and you can check to see if your nut threads easily on a known bolt.
You must not have "determined" kids that will get that 10-24 nut on the 10-32 bolt. Yeah sure, it'll go on...with enough torque.
Unread 23-12-2014, 22:14
Oblarg Oblarg is online now
AKA: Eli Barnett
Quoting for truth. As mentioned earlier in the thread, our solution to this problem is to just not buy 10-24 anymore, which removes the potential for the error in the first place. On a team as large as 449, it's just not worth the hassle for the few places where it's nice to have coarser thread.
"The breakfast of champions!"
