#16
Re: pic: Swerve again, for fun
![]() We can presume that Kevin from 2451 has a pretty good guess for how much it weighs when he says Quote:
#17
Just curious, is there any way we can get our hands on the CAD files to take a closer look at the module? I know this may be a stretch but worth a shot too: If a team wanted to build this, would the spec sheet include all the parts that come together to make this?
#18
I could go design a 4 lb swerve now, no guarantee it will work or hold up. Many of the recent designs posted aren't robust enough to survive a season (I think Aren's here would though, as he's fielded 5+ swerves at this point I think). |
#19
I have to ask were some of the concepts for this taken from my teams designs i posted over the summer? Looks really clean and well thought out.
http://imgur.com/a/H6Qcm |
#21
Given that, I think it's possible that this weighs more than many designs posted previously. However, it is much more compact, and for many situations that can be more valued than the weight. If you believed that none of the recent designs can survive the season, then you really should have said so ealier, when those designs were posted. Also, I found this yesterday: http://www.chiefdelphi.com/media/photos/34178 So Aren beat himself some years ago. ![]() EDIT: How is the bevel gear constrained axially on the shaft? Does it depend on the wheel to position itself properly? Last edited by asid61 : 22-12-2014 at 23:25. |
#22
This years game was hard on our swerve modules but they are still going strong. I would pick a robust module over a cute light weight module any day. So I say to those who have caded all those modules in the off season, Make them and beat them. Do they perform and survive? Then it is a good design. Until then it's just a concept. We made a CVT module this off season. Do we do it this year? I don't know. I'm leery of adding complexity to an already complex system. I guess it depends on the game. But, we made it and tested it. Made revisions and beat it. First has become brutal. Will 2015 continue this trend?
#23
The larger gear in Aren's design might be larger but the smaller gear is much smaller. I would go off tooth size and not OD of the largest gear. Our actual module weighs in at 7.5 lbs with no additional lightening of the gears, etc. This is too be expected since all the steel screws weren't added to the CAD model. We'll post a video of it driving around just as soon as it is, should have it powered up this afternoon. |
#24
The weight comes not only from the teeth but the face of the gear I think, as well as the hub. As the diameter of the gear increases the area/ volume of the gear increases considerably. You actually made your module? Super cool! I'll be looking forward to seeing it driving. |
#25
Great looking swerve Aren!
When you get it working Kevin, it would be awesome to see a video of it working! |
#26
Example: I led the design on this module as well as the 2010 6 wheel swerve. |
#27
(And if I made that tiny module, the lightening pattern would've been way cooler looking ) |
#28
How did 6 wheel swerve work out? |
#29
also: Finalists at GKC along with Engineering Excellence, Semi-Finalists at Midwest along with Regional Chairman's Galileo Division Champions Never ranked lower than 3rd after quals at any regional or champs, overall season record of 36-13-1 sooooooo... *Fun fact, only 6-Wheel Swerve to ever be on Einstein |
#30
Aren never ceases to break my head with his designs. The non-coaxial power transfer is so cool. I like how you use the 16-style bearing thing to avoid using any shafting at all holding the module up. I like how your crazy ideas make complete sense in terms of the problems you're trying to solve.
It doesn't look like you have any sensor feedback on the wheel (velocity, you have a thing for angle i think). Do you have something planned for that? This seems like a cool application for that on-CIM encoder that's been going around CD these days. Quote:
