Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 08-01-2003, 00:58
Allenwolf's Avatar
Allenwolf Allenwolf is offline
#0647 (Cyber Wolves)
Allenwolf is an unknown quantity at this point
Send a message via AIM to Allenwolf Send a message via Yahoo to Allenwolf
Isaac16 Motherboard
I was reading the inovvation First site and on www.ifirobotics.com they have the Isaac16 for sale and extra motherboards. What I was wondering if the Isaac 16 we got in the kit has this feature of a removable motherboard.
Cyberwolves! Whoa!
Unread 21-01-2003, 21:26
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
Without removing any screws, you can remove the circuit board and jumpers from the controller, but the only chip left is very small and presumably used to interface the LED's and jumpers or something.
After removing three (of four) screws, there does appear to be two easily separated circuit boards inside. I didn't want to void the warranty since it's not my controller, so I didn't look any further than that.
Adler Attack #933 -- Trigos
Unread 01-03-2003, 16:47
Since you can leave the external circuit board on your robot, and just transfer the box to another robot, I would guess that the chip you saw on the board was the memory for storing your robot's program. The rest of the contoller (in the box) includes all the outputs, which a dead robot doesn't need.
Unread 01-03-2003, 17:50
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
The Issac16 in the kit has a removable motherboard. The thing with all the inputs and outputs is the motherboard, and the black box that it snaps in to is the actual Issac16 unit. You shouldn't need to unscrew anything.
Zan Hecht
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
