Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 24-12-2014, 15:47
hypersonictom's Avatar
hypersonictom hypersonictom is offline
Design and Build Lead
AKA: Thomas Adamson
FRC #1983 (Skunkworks Robotics)
hypersonictom will become famous soon enough
pic: FRC 1983 Skunk Works Robotics 2015 Preseason Drive Base
Unread 24-12-2014, 15:53
AKA: Thomas Adamson
Re: pic: FRC 1983 Skunk Works Robotics 2015 Preseason Drive Base
Meet our preseason drive base Slippery Biscuit. In the past we have designed a rectangular chassis and it has worked well for us. Because of the nature of last year's open field, we ran into major issues with friction pinning. These issues became more prominent when we competed against robots with 3 CIM transmissions versus our 2 CIM transmissions. So, for this year's preseason project, we choose to design and build a drive base that contained some good solutions to friction pinning to determine how well they work and how to build them during build season. This design has redundant friction pin solutions. The link the the CAD model is https://drive.google.com/open?id=0By...VkE&authuser=0
Features:
The drive base features a sheet metal, 6 wheel tank drive with a dropped center wheel for improved maneuverability. It has an octagon shape with an outward slope of 25 degrees yielding a larger platform and a geometry that allows steering out of a friction pin situation. This is inspired by FRC Team 971, Spartan Robotics. All wheels are VEXPro 4 inch traction wheels using Blue Nitrile Rough Top tread. The front and back wheels are 1 inch wide riding on dead axles while the center wheels are 2 inches wide on a live axle. The center wheels are driven by a chain off the transmissions. The chain is tensioned using a cam that positions transmission. The outer wheels are driven off the center shaft using 9mm wide, 5mm pitch HTD belts on 42 tooth VersaPulleys. The belts are tensioned by adjusting the position of the dead axles.
The transmissions have custom water jetted and milled aluminum bearing plates and standard Andymark Supershifter gears/shafts with 3 in-line CIMs. A dog-shifter enables a high gear ratio of 4.82:1 (16 fps) and a low gear ratio of 12.35:1 (6 fps). Speeds are calculated at 81% of CIM free speed. High speed reduction is 12:40, 28:35, and 19:22. Low speed reduction is 12:40, 15:48, and 19:22. The only custom gear in the transmission is 3-D printed idler gear that drives a Grayhill encoder.
In between the outer and center wheels are drop omni-wheels that are pneumatically deployed. This enables the robot to pivot out of friction pinning situations. This feature is inspired by FRC Team 118, Robonauts. This design features a departure from our traditional two-color Velcro bumper system. Here we are studying a single piece bumper system that is easily removed, yet rugged under heavy defense. Over-centering toggle clamps retain the bumper by pinching a flange attached to the bumper against the top of the chassis.
Things we would like to investigate further:
Instead of using a chain to drive our center shaft, we would like to drive it using gears. We will not place the air tanks in the frame. We thought it would be a good use of space since we wanted a box frame in the front and back, but the tanks are difficult to service if a leak occurs. As for belts, they are nice and light but they are difficult to remove/replace.
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Looking good, can't wait to see it in action! Great job on the model.
It was looking pretty far along last time I visited, how soon until the Slippery Biscuit hits the carpet?
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 24-12-2014, 15:57
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Originally Posted by hypersonictom View Post
Purpose:
Features:
The transmissions have custom water jetted and milled aluminum bearing plates and standard Andymark Supershifter gears/shafts with 3 in-line CIMs.$@# A$@#dog-shifter enables a high gear ratio of 4.82:1 (16 fps) and a low gear ratio of 12.35:1 (6 fps).$@# Speeds are calculated at 81% of CIM free speed. High speed reduction is 12:40, 28:35, and 19:22. Low speed reduction is 12:40, 15:48, and 19:22. The only custom gear in the transmission is 3-D printed idler gear that drives a Grayhill encoder.
Looks great.
My only suggestion would be to replace that center chain with gears for sure. We have had alot of trouble in the past with a single chain driving an entire side of the robot. That chain fails, and you are dead in the water the rest of the match. Plus moving an entire transmission to tension a chain is a pain.
Team 4488 - Mentor 2013-2016
Unread 24-12-2014, 16:04
Oblarg Oblarg is offline
AKA: Eli Barnett
Out of curiosity, how much does this weigh, sans battery and electronics?
"The breakfast of champions!"
Unread 24-12-2014, 16:05
AKA: Thomas Adamson
Besides a few missing parts for the belt tensioners, the robot mechanically is done. Since we decided to use roboRIO for it after we had made the design, we are lacking few electrical components for it and won't be able to install those until the beginning of build season. I think we should be looking at operating it by the end of the first week of build season.
Unread 24-12-2014, 16:09
Ken Zaballos's Avatar
Ken Zaballos Ken Zaballos is offline
Ken Zaballos is on a distinguished road
Of course, this will not be used for competition. It will be a test bench for the programming team.
Unread 24-12-2014, 16:15
AKA: Thomas Adamson
The drive base with battery, electronics, and pneumatics weights approximately 54 pounds. So this doesn't include the bumpers. The drive base frame by itself weighs about 15 lbs.
Unread 24-12-2014, 17:00
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
T
What type of 3d printer are you printing your gear off of?
Also I see you included handles in your design. Out of curiosity what material are you planning on using there and where could I buy it.
In all looks like a really well made design. I bet no matter what the game you won't have to worry about using and abusing it through a whole season. Solid drive train.
Unread 24-12-2014, 17:05
http://www.mcmaster.com/#standard-pull-handles/=v6194w
We have found handles to be an important feature of our robots. they go into the model at the beginning of the design to be sure they are not an afterthought.
Unread 24-12-2014, 17:10
AKA: Thomas Adamson
The 3-D printer we use I believe is a Stratasys Dimension 1200es or a similar model. As for the handles, we got them from McMaster-Carr.
Here is the link http://www.mcmaster.com/#standard-pull-handles/=v61cau
Unread 24-12-2014, 23:01
Cash4587's Avatar
Cash4587 Cash4587 is online now
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I would look into Team 148s off season hex drive train. They did sheet metal as well and it seems as they found that any more angle than 8 degrees didn't help much with friction pins. I'm not sure in that though so don't quote me, but do check it out.
Unread 25-12-2014, 18:23
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
I thought you could not use your off season stuff for the upcoming build season?
Unread 25-12-2014, 18:35
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
Flimsor will become famous soon enough
The rules may have changed, but I remember there being something about being able to use pre-season work so long as it's publically available before kickoff (feel free to correct me if I'm wrong). We've never completely reused a design, though, since there's usually much more integration of the drivebase and with the rest of the design, and we get curveball rules that require some dimension changes. Even still, we make a new model during build season (though it ends up being pretty similar to anything we previously did)
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 25-12-2014, 19:07
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
They won't be competing with this drivebase, so it doesn't matter.
(2015-?): 973
(2012-2015): 955
