Go to Post Luck *good or bad* and opportunity will always affect what happens to teams. - Brian C [more]
Unread 25-12-2014, 12:08
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Designing for Powder Coating
Originally Posted by dradel View Post
Keep in mind when powder coating you must use high heat masking tape. For masking holes I have found silicone tapered plugs work best.
Couldn't you just pull the tape off after you have sprayed the part with powder? That way you aren't actually putting any tape in the oven. I am asking, I have never tried to powder-coat before.
Unread 25-12-2014, 12:23
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Would end up taking off the powder around it if you weren't beyond careful.
Unread 25-12-2014, 12:26
dradel's Avatar
http://www.eastwood.com/silicone-pul...-d-125-pc.html
Unread 25-12-2014, 13:24
Alex2614's Avatar
Alex2614 Alex2614 is offline
Scapegoat Mentor
AKA: Alex Stout
FRC #2614 (MARS)
Alex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud of
Send a message via AIM to Alex2614
We have been powder coating for six years now. We usually do a two-tone job, but little parts that are added later (braces, dust covers, etc) we usually juts spray-paint. You can't really tell the difference unless you're up close. We have been known to make a couple extra of parts that we know may need to be replaced and have those painted as well, but most replacement parts are not coated.
Because our sponsor donates the coating, labor, etc., we always prep the parts for them. We clean it pretty thoroughly, and then have a "sanding party." Everyone chips in on this part and sands the whole thing (through holes, inside crevices, etc.). The whole process usually takes a few hours, but many hands make light work.
If you have any questions, I'd be happy to answer. Just PM me.
MARS - Mountaineer Area RoboticS Team 2614, Morgantown, West Virginia Website Facebook Page
2016 season in memory of Phil Tucker
We came to be inspired. We stay because we are. We will become the inspiration.
2016 Championship - Newton quarter-finalist, Hopper-Newton Gracious Professionalism Award
2016 Regionals - Finalists (x2), Chairman's Award, Gracious Professionalism (x2), Industrial Design
2015 Championship - Hopper Finalists
2015 Regionals - Chairman's Award, Regional Champions, Gracious Professionalism, Woodie Flowers Finalist
2014 Championship - Innovation in Controls Award
2014 Regionals - Chairman's Award, Champions, Finalist, Entrepreneurship, Gracious Professionalism, Dean's List Finalist, Creativity
2013 Championship - Entrepreneurship Award
2013 Regionals - Engineering Inspiration Award, Entrepreneurship, Dean's List Finalist
2012 Championship - Woodie Flowers Award
2012 Regionals - Champions, Chairman's Award, Finalist, Innovation in Controls
Unread 25-12-2014, 13:34
DampRobot's Avatar
Physics Major
AKA: Roger Romani
100 did all of our own powdercoating last year, and I did a lot of the work myself. It's fair to say we made a lot of mistakes (especially in the offseason when we tried it for the first time), but I was very satisfied with the results overall.
When the pros do it, they can get a real thin even coat, but when we did it, we kind of just tried to get as much paint on there as the gun would give. This ended up being as little as 5 thou in places, and as much as 30 thou in others. I'd expect professionals to be around 3 thou, and even throughout the part.
Definitely only send out parts you're sure are right. Just test at fit everything together so you can be sure you're using your sponsors time on stuff that will work right. Also on that note, they probably don't want a slow trickle of parts as you manufacture them, they probably want one big set of parts all in one color.
Originally Posted by craigboez View Post
For teams that use a WCD chassis, do you make any specific allowances for the pockets in the siderail that the bearing blocks ride in?
Yes, defiantly. We did the VersaTrucks thing last year, and we just masked over anywhere where the VersaTrucks was going to touch the frame. For you, I'd recommend masking over the hole, so the edges are just as they were milled. No one will see it, it's under where the wheel is.
Has anybody weighed their chassis before and after powdercoating - how much weight should I expect it will add?
Yes, we did. If you're less lazy them I am, you can search my past posts to find the real number (it's been a while), but if I'm remembering correctly, it's something like 3-5 pounds if you PC most of the robot. However, I'm sure that number would be very different for pro vs amateur PC and for different robot shapes, etc.
Yeah, we tried a bunch of stuff, a lot of it just burnt or melted into a disgusting goopy mess. Kapton tape worked well, it's designed for real high temperatures, and leaves a clean edge. It's a bit expensive, but you don't use that much and it's definitely the right thing to use for PC masking. I think you can get it on MMC.
In terms of surface prep, we did everything ourself. First, we did a wash with water and simple green, and then sand blasting, then another simple green wash to get the sand off. Then, we were ready to mask, spray and bake. Keep in mind that good prep takes a really long time, and you can get good results without it, but without solid surface prep, PC is real hit and miss. We ended up regretting most times we didn't prep well. Talk to your sponsor about what they want.
-Plutarch
