Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Unread 25-12-2014, 19:02
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: pic: Proto Type Base Built
Which part of the drive do you use to strengthen the frame from front to back? Do you use the transmissions as stress members?
What I was talking about in my last post would look something like this:
\|__|/
(with the dotted front rail being at the front of the robot, I don't have a character that is a high horizontal line)
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 25-12-2014, 20:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Here's the image from the team 1322 site:
Built that in two hours? Wish we could get our build team anywhere close to that speed.
Unread 26-12-2014, 10:47
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
As shown above we use a special built bracket that we made for the super shifters to help strengthen the frame. We removed the 5 x 5 square tubing from the gear boxes and replaced it with the bracket which allows us to move the frame up a few inches in the bumper zone.
http://www.team1322.org/20140612_201621.jpg
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 26-12-2014, 10:59
Oblarg Oblarg is offline
AKA: Eli Barnett
Extremely non-conventional, but very cool, especially given the construction time. Maybe provide a video of it driving eventually?
"The breakfast of champions!"
Unread 26-12-2014, 11:09
philso philso is offline
FRC #2587
What happens to your frame when you apply a compressive force on two diagonally opposite corners? It seems that it is the two U-shaped pieces of square tube that keep your chassis from "parallelogramming".
Is there a reason you chose to use two u-shaped pieces of bent tubing vs. a single straight piece down each side? It seems that the manufacturing tolerances (bending cutting drilling) would have to be pretty tight to keep the six axles parallel to each other. How are the axles for the front and back wheels attached to the two left/right frame members? The holes for these four axles are not perpendicular to those frame members.
Unread 26-12-2014, 14:54
joeweber's Avatar
Coach team 1322
Depending on the game we will have sheets mounted to the frame to mount electrical and other items, this will give directional strength. If we use #35 chain we can just mount pillow blocks to the frame at the correct chain tension and that will take care of the axel mounts. I want to keep it simple for the students to build.
Unread 26-12-2014, 22:58
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The bracket mounting the gearboxes looks like a flat bar. Does it have any extension in the vertical direction? If not, you may have some flex in this member in a head-on or rear-end collision. This could momentarily reduce the chain tension. Combined with the sudden change in the traction force this could lead to losing the chain from the sprockets. I would actually consider that bracket (or some supplementals) to be part of the chassis rather than just a gearbox/wheel mount since it provides the continuous front-rear loading.
Also, why the 1-3-1 wheel count per axle? Does it help traction that much, or do you figure that it'll reduce the fraction drive force that must be delivered by chain (vice direct drive)?
I'm also in agreement with philso as to feeling queasy about not keeping the wheels aligned in a diagonal collision, or more properly with not keeping the sprockets in the same plane and losing the chain. We have never depended on a control board for this; at least since our second year we either used triangular structure or large (8") flat braces on everything but our wooden prototypes. I wasn't in the mix our rookie year (Rebound Rumble), but the control board was vertical, so it wasn't providing stiffness. On the other hand, I don't recall many robot-to-robot collisions in RR, so we may have just skated on that one.
Thinking about the things that can go wrong with this design makes me like the simple pseudo-WCD* design we're using for our prototyping tank chassis - short of bending the main c-channel members, there's no way a bumper collision can mess up the sprocket alignment or spacing.
* Pseudo-WCD in that we're using cantilevered axles, but not direct driving the center shaft. We're also using wheel bearings on fixed-mounted axles so imperfect machining won't cause (as much) wobble. Along the same line, we're using COTS shifters: AndyMark Super Shifters, but the design is adaptable to Sonic Shifters with just two more holes in the chassis and longer chains.
Unread 26-12-2014, 23:36
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Oh - but I do like the idea of having one double-ended piston drive both shifters. Since the high gears must be on the motor side of one gearbox and the wheel side of the other, this is probably not a COTS gearbox, or at least a reconfigured one.
I thought for a while that these might be AM Super Shifters with the spacers instead of the extrusion, with the one on the left in the picture built with a lot of pieces backwards (both plates, and the plates on the left gearbox in the picture flipped so the shafts line up, as well as the high/low swapped on the dog and drive axles). Even with all that, the location of the gears on the shifter shaft don't quite work out; one side would be in low gear while the other was in high - am I missing something?
Unread 27-12-2014, 08:54
joeweber's Avatar
Coach team 1322
Here is a picture of the mounting plate for the super shifters. We used the same drive layout last year and had no problems. We added the additional wheels in the center for more traction. How strong the frame will be we will find out if this years game allows.
