Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 01-03-2003, 19:08
Tyler 178's Avatar
Tyler 178 Tyler 178 is offline
#1294 (Screws Loose)
Team Role: Driver
Tyler 178 will become famous soon enough
Send a message via AIM to Tyler 178
Looks like a pretty good bot. The back wheels should have a lot of traction w/ all the weight over them. (probably at least 40 lbs w/ 12 pound battery and 12 pound compresser + everything else)
w/ only boxes only weighing 5 lbs each though, seems like it would be back heavy and top heavy.
Too bad your sign blocks view of the inside of the robot.
Btw, i like the hinged doors on your crate in the background, wish our team had thought of something cool like that for our crate, or at least made our crate something other than just boxed up crate.
Hopefully your bot can do fine small turning.
It seems that this year to stack, bots must be able to turn precisely, to orient stacker mechanism in front of boxes.
Kyle, looks like black stuff on arms is for grip on boxes, and almost looks like it may be able to squeeze.
The little white discs on the corners of your bot look cool too. Are they just for deflecting bots from pushing on you?
What do you think of team 131 CHAOS? Pros/Cons archiver 2001 21 24-06-2002 01:45
No Petition for CHAOS archiver 2000 2 24-06-2002 00:01
petition to suport CHAOS archiver 2000 3 23-06-2002 23:58
Team 131 'C.H.A.O.S.' robot design archiver 1999 0 23-06-2002 22:37
CHAOS and US Air archiver 2000 0 23-06-2002 22:32
